6p3p tube amplifier kit - Page 16 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Siliconray Online Electronics Store
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
Old 5th February 2014, 07:38 PM   #151
Pdwhitt is offline Pdwhitt  United States
Default Pic of Siliconray 6P3P
Here's a pic of my 6P3P, front panel from left to right: power switch, feedback resistance control, volume, dimmer for lamp, and power on indicator lamp.
Old 6th July 2014, 09:58 AM   #152
Default Problem. Very low sound
This is a technical question. I have just received and built the 6P3P amp and I have a problem. The sound is very, very low although the volume pot is all way up. I can fairly hear it. Some measurements I made and I have encountered that at the first capacitor of the PSU, there is only 180v dc., without the choke, there is 350v dc. Could be the choke broken?
Also at the pins 3/8 of the 6N1 tube, there is more or less 1v dc and not the 1.75 stated.
Please help,
Jorge
Old 6th July 2014, 11:47 PM   #153
Please help,
Jorge
Where is your star ground point?? Be sure your speaker post grounds are attached to that ground point. Turn it down once you square that up so you dont blow up your speakers. There's other ground points too from the volume pot as well. Check them all..
Bob
Old 7th July 2014, 08:06 AM   #154
Default Very low volume...
Bob
Hi Bob,
Thank you for your answer...!!
The star ground point is located at the (-) of the 330mf/450v capacitor of the power supply. I have made some tests and I feel that the problem could be at the output transformers. I have reached this conclusion because I changed the choke for a resistor and the behaviour is the same. If I have the output transformers connected, the psu voltage goes down to 198v, if they arenīt, the psu voltage remains ok around 310v. I have tested other tubes, all ok because they are tested before so the tubes arenīt the problem... but...could both output transformers be bad?
I have checked all connections and to my eye they seem ok.
I am running out of ideas to check.
Help appreciated....
Jorge
Old 7th July 2014, 11:59 AM   #155
Hi Bob,
Jorge
Try reversing the connection to the opt transformers?? Do you have feedback connection from the output back to the input?
Bob
Old 7th July 2014, 12:10 PM   #156
Bob
Hi Bob,
I havenīt done that...I thought about it but did not reversed the the connection to the opt transformers...If they state red to plate and blu to B+ thatīs for me correct...If it works this way I couldnīt believe that....!!!
I have the 10k feedback resistor installed although this kit is different from the first one I built, with a 2k feedback resistor and additional 100 Ohms in series with the 1k cathode resistor and a 100 mF elect. cap bypassing it. I did not installed these components, I made the same as the first 6P3P amp I built. With the 10k feedback resistor and only 1k cathode resistor.
Jorge
Old 7th July 2014, 05:32 PM   #157
Hi Bob,
Jorge
You should have a cathode resistor bypass cap in there. I would put that in there first - that may be your issue.
Bob
Old 7th July 2014, 05:37 PM   #158
"usually" red goes to B+ and Blue goes to Plate - why I suggested the switch - I'd send a e-mail to Ray about that maybe the wire colors are reversed. What I just suggested is the "NORM" with most transformers manufactured today...
Bob
Old 7th July 2014, 06:02 PM   #159
Bob
HI BOB,
In my first 6p3p amp from SiliconRay, there where no bypass cap whatsoever in the 1k cathode resistor. And the amp is running fine and sounding very nice indeed. Maybe that cap makes the sound better, but I think in my humble opinion that near no sound at all could be more related with the opt transformer cable reversed or worse, a faulty opt transformer. The only thing I must recognize is my doubts that both channels behave the same....
Jorge
Old 7th July 2014, 06:05 PM   #160
Bob
I hope you are right... I did installed based in my previous 6P3P...One of my checkings was to unmount the opt trans. and check the label underside and with google check the colors (they are in chinese) ...they state red to plate and blue to B+ so I did that. I did not try reversed because my lack of knowledge if that way was going to blow up something....
Best Regards,
Jorge
Cheap 6P3P SE Kit (with case) siliconray Vendor's Bazaar 14 8th February 2012 03:32 AM
Class A tube amplifier Kit lduarte1973 Tubes / Valves 32 30th September 2011 11:26 PM
Burned Up Transformer in HiFi 6p3p Tube Amplifier dmitch31 Tubes / Valves 3 26th February 2009 03:40 AM
Tube Amplifier Kit? theblackknight Tubes / Valves 11 14th February 2008 07:55 PM
PCL82 SE Tube Amplifier Kit savakovacevic Tubes / Valves 4 28th January 2006 09:41 AM
Copyright Đ1999-2017 diyAudio
