6p3p tube amplifier kit - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Siliconray Online Electronics Store
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
Old 15th May 2013, 01:12 PM   #121
Pdwhitt is offline Pdwhitt  United States
The output transformers are labelled in Chinese. Best I can tell, it looks like black is ground, yellow is 4, and green is 8 ohms. Red is P coming from pin 3 on the 6p3p, and blue is B coming from pin 4. Can anyone confirm this?
Thanks!
Paul
Old 15th May 2013, 06:15 PM   #122
Thanks!
Paul
Blue is B+ you can take it from anywhere after the power supply usually at or shortly after the third cap C3 22uf 450V. You can connect the blue to pin4 OR + terminal on C3.
Red connects to pin3 (signal out for output tube)
Output wires
Black is 0 (Neutral) - be sure you get both connected together and run a wire (black) back to your star ground point (bolt on the transformer).
For the output transformer color codes - I'll have to check when I get home, I don't remember which color is which.
Here's a way to tell....
Measure ohms reading from Black to yellow and black to green. The reading with the lowest resistance to common will be your 4 Ohm tap.
Hope that helps.
Bob
Old 19th May 2013, 03:25 PM   #123
Hi guys, was wondering if anyone else has tried the diode mod Bobrown has suggested.
With further reading on other posts on the subject, i got the impression, at least with the 5y3 tube that this becomes a solid state rectifier and the tube itself becomes redundant.
Can anyone clarify this for me that i understood this right (Bobrown if your out there, any thoughts on the subject).
If so, i don't see the point in buying a new rectifier tube just yet if i try this mod.
In the meantime i have some russian 6p3s tubes and a tocos volume pot i have read good things about on there way, so hopefully can let you all know of any improvements these might add.
Scratch
Old 19th May 2013, 08:39 PM   #124
Just finished my 6p3p and will post some pics and building notes later. This can be a very good first diy tube amp if you study the schematic and wiring diagrams. The stock amp looks awesome, is quiet, sounds good, and with a few simple mods (rectifier diodes, new power tubes, and feedback resistors) is plenty loud enough and sounds great!
Paul
Old 19th May 2013, 08:46 PM   #125
I ended up with 330k feedback resistors, and these sound about right for my 6p3p. Has anyone tried installing a variable feedback resistor?
Old 19th May 2013, 09:10 PM   #126
kevinkr's Avatar
Wire both primaries in parallel or you may fry the transformer. The primary windings are sized based on the primary current when the windings are wired in series for 220-240V operation, when operating on 120V the current consumption will be twice that at 240V which could result in excessive heating in a single primary, the winding current is correct when both are wired in parallel..
Bob,
The extra pair of red black seem to be identical to the first pair. If i connect 120v AC to the first pair of red black, the second pair reads 120 and all the other voltages (300, 6.3, 5, and 3.15) are correct. If i connect the second pair of red black to 120 wall outlet, then the first pair reads 120, and all the others again show correct voltages. So I guess I will not use the second pair of red black wires, and will secure them out of the way.
Thanks!
Paul
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th May 2013, 09:31 PM   #127
So, I will put the two red wires together and wire them to one side of the wall AC current, and put the two black wires together and run them to the other side of the AC inlet.
Thank you Kevin!
Paul
Old 21st May 2013, 07:43 PM   #128
Scratch
Diode mod is there to protect transformer in the case of arc over in the rectifier tube, primarily a safety feature. Does not make the rectifier tube redundant. You keep all the properties of the rectifier tube (slow start & resistance & voltage drop) these all make a difference in performance of the power supply & subsequent circuits.
Arc over in rectifier tube = toasted transformer for this amp, add diodes no more worries.
Of course there are many ways to tame that cat. Some rectifiers are getting pricey so you can protect the rectifier tube and the power transformer with this simple $.24 mod.
Bob
Old 23rd May 2013, 10:33 AM   #129
6n1 is offline 6n1  Spain
Default Bad expierence with tube seller
Hi there , I have had a bad expierence with a Russian tube seller :ruTube.com I ordered some capacitors and tubes payed trough paypal and started to wait after 3 weeks I cancelled and this guy ( Nikolay ) sended me an Email explaining that there were holidays in Russia , so he convinced me I opened the acount and since then nothing he does not aswer my Emails . If you guys have some good experience post the names . With regards Paul
Old 23rd May 2013, 11:12 AM   #130
The holiday is May day (May 8th & 9th) - 2 days off work. I've had to wait a month from a few Russian sellers to get parts, and others I've only had to wait a week or so. Last order from RU took a month, I've always gotten parts.
Bob
Cheap 6P3P SE Kit (with case) siliconray Vendor's Bazaar 14 8th February 2012 03:32 AM
Class A tube amplifier Kit lduarte1973 Tubes / Valves 32 30th September 2011 11:26 PM
Burned Up Transformer in HiFi 6p3p Tube Amplifier dmitch31 Tubes / Valves 3 26th February 2009 03:40 AM
Tube Amplifier Kit? theblackknight Tubes / Valves 11 14th February 2008 07:55 PM
PCL82 SE Tube Amplifier Kit savakovacevic Tubes / Valves 4 28th January 2006 09:41 AM
Copyright 1999-2017 diyAudio
