Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
6j4+6p6 hifi preamplifier kit!
Old 17th March 2012, 10:19 PM   #21
sled108 is offline sled108  United States
sled108's Avatar
Thanks Bob....One of the PT Bolts can hit a Terminal Lug on the Power Switch...Ouch....
I cut 1/4" of It so that the Switch would be able to Mount Flush on the Front Panel...
Old 18th March 2012, 12:37 AM   #22
sled108's Avatar
Here it is with the Lights On....
Old 18th March 2012, 06:10 AM   #23
sled108's Avatar
This is Nicer...
Old 18th March 2012, 06:40 AM   #24
siliconray is offline siliconray  China
It's OK to use 6j4p to replace 6j4 in the kit. slightly difference.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 18th March 2012, 04:39 PM   #25
sled108's Avatar
I keep losing that Link...
6j4+6p6 hifi preamplifier kit!-preamp-glow-jpg
Old 19th March 2012, 02:44 AM   #26
Looks like a Mercedes
Chat with me
Old 19th March 2012, 05:58 PM   #27
sled108's Avatar
Hey Ray...Can you please Post a Pic of how the Selector Switch is Wired? I has only 3 Positions, but the Case has 4 Inputs...
Old 20th March 2012, 01:37 AM   #28
Sled, same here. Maybe it's reserved for some other kits. It's not designed by Siliconray. Several kits share the same chassis, that's probably the way of reducing cost. I mounted a pair of RCA there but with nothing connected.
Chat with me
Old 20th March 2012, 02:24 AM   #29
Tanner is offline Tanner  United States
I removed the plate behind the jamb nut. If you rotate it you can gain or loose the number of positions the switch has. I think it has 8 or 9 but you can adjust it to have just 4
Old 20th March 2012, 02:57 AM   #30
sled108's Avatar
No Poop? ...Learn something new Every Day..Thanks...
And, if you want to lower the Gain, it's Way Easier to just parallel the 24K...Use an OnLine Calculator...I've found that a 10K over the 24K gave 7K, it helps a Bit...Not very much, so I then tripled with a 5.5K that made it around 3K, but I think that Messed up the Sound...I'm keeping it at 7K for now until the New Alps gets here on the Slow Boat...
6j4+6p6 hifi preamplifier kit!Hide this!Advertise here!
HiFi DIY's mini-A kit amp acebritbiker Solid State 17 3rd May 2013 10:11 AM
6J4 Experiment! DualTriode Tubes / Valves 17 20th March 2011 01:16 AM
Diy HiFi Supply Tram Mk2 DHT OTL Preamplifier otto88 Tubes / Valves 1 2nd October 2010 07:30 PM
6j4 oscillating? Klimon Tubes / Valves 2 18th January 2008 09:32 PM
Which Audio (hifi) Sub kit do you recommend? Rafal Subwoofers 25 17th July 2007 04:04 AM
