diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
MOSFET 'slightly high frequency' power amp - Click HERE for Original Thread
davebray
Hi all,
Very new to this game, (at least this end of the frequency spectrum). Here is my problem. I find myself trying to design an amplifier that doesnt quite fit the usual bill. Let me explain.
I need an amp that will work at and around 100KHz -> 150KHz, as I say not the usual audio style. It also needs to be very efficient because its going to be run from car battery +12V, in the field and sit there for a while.
Class-D springs to mind, but of course most sane people out there are making amps that output things people can hear!!!
The amp does NOT need to be particularly 'good' i.e. THD is not too big an issue, especially since I can't hear it.
The output of the amp will drive an inductor / arial and produce an RF output signal.
Would love the circuit to be 'power tunable' i.e. be able to dictate how much energy I drive into the coil depending on where it was sat.
It would be nice if component count was low, again one thinks of using say a IR2011 to take some of the donkey work out.
Cost is not really too big an issue.
So sounds easy, but can't find anything like it our there.....
Anyone got any suggestions ?
Dave Bray
RF specialist
fredos
Class BD at your frequency with small filtering inductor!
Fredos
Ouroboros
Would this be for communication with cavers?
Ouroboros
To add to my previous post.
Signals in this range may be receivable a few feet underground, so I wondered if the intention was to drive a frequency modulated carrier at 120kHz or so, with a simple receiver underground using a ferrite rod antenna and a PLL FM demodulator.
I guess not, as you wouldn't need a linear amplifier for that.
phase_accurate
If just a carrier is needed then a class-c amp is the best solution.
Charles
richie00boy
What output power/voltage swing do you need? That will dictate quite a lot!
fumac
interesting:)
canu tell us more info, perhaps my MCD can help u:)
rg
fumac
jackinnj
there is now a little slice of the VLF spectrum for experimental use in the US -- perhaps in the UK as well -- if so there may be an article on such a device in the RSGB magazine "RadCOM".
phase_accurate
In my homecountry this is 135.7-137.8 kHz for instance but others have priority using this range.
Charles
davebray
I am overwelmed by the amount of response, its fantastic.
A little more information is required here.
What I am trying to do is build an antenna as you all quite rightly guessed. This would be fed a very narrow band frequency 134.20KHz and I want that transmitted as energy into free space.
The other end of this is a tiny transceiver which is 'charged' up by this pulse and replies back to a receiving station.
If anyone is interrested the tiny transceiver is made by Texas Instruments and is an RFID component.
A link to the tiny transceiver module below.
http://focus.ti.com/docs/prod/folde...rp-rr2b-20.html
The trick with these little guys is to send out a pulse say 30mS long of energy at exactly the right frequency which will charge up the tiny internal capacitor encased in the chip.
As I mentioned before, the unit needs to be 12V (car battery) powered because it is going to sit in a field. Energy efficiency is a must as even a car battery has a limited amount of energy.
Of course this means the amp can be highly specialised, it only actually needs to amplify frequencies in a very narrow range.
As you might imagine TI do a single chip solution with a full bridge amp in it but it is very small and produces a range of only a few centimeters. I need something that will reach perhaps a meter.
As for spec, well the TI chip produces a 134.20KHz square wave which it feeds into a tuned LC circuit, (The L being the antenna naterally). Taking a scope and measuring some voltages I see with the tiny driver approx 100V across the antenna and a drive current around the 500mA.
Doing some math I calculate to reach say 70cm with the r3 law I would need 2.5A of drive at 250V. But I am certianly no EMR expert.
Once again thanks for all your replies, Ill post a circuit diagram of my 'prototype' with the next posting they may help to answer some more questions you all no doubt have.
Dave
phase_accurate
So you need just a short burst at the right frequency ? No modulation at all ? Am I right ?
Charles
jaybombalous
I am just gonna ask a silly question...
But 'in the field' means to me anywhere u can park the car.
Why do u need charge a remote cap a 'step' away further then the one that came with the transponder?
Maybe I just missed the whole point of your project, but please carry on.
BWRX
quote:
A class d amp with the LC output filter tuned for a very high Q response at 134.2kHz?
phase_accurate
Although it most probably isn't a class-d amp but rather a class-c one you get it right: Small-bandwidth signal-transformation can be and are done by the use of resonant circuits.
Charles
davebray
Well to kind of continue, yes the amp needs to provide energy into a tuned LC circuit and to do this every 50mS or so, so bursts 20 times per second.
The whole idea is to tie the little transponder to something and then move it past your ariel reading its responce once its charged up it sends back a response.
So 134KHz into a tuned LC circuit (L being an ariel) looking at Q factor etc perhaps an output of 60V peak-peak +-30 and current of around 2 - 3 AMPS is just about right.
Any thoughts what would do it ?
Dave
fumac
davebray
if ur kit want to use in RFID card?
or Tire Pressure checker?
i think yes
rg
fumac
davebray
The Class D AMP from fumac sounds like what I need.
It will probably be a little over the top but hey.
fumac can you email me details of the AMP so I can take a look
dave@racetimingsystems.com
Cheers
fumac
dave%racetimingsystems.com
Cheers
hi dave
had mail u
rg
fumac
Page generated in 0.044504880905151 seconds with 17 queries,
spending 0.00790095 doing MySQL queries and 0.03660393 doing PHP things.
