diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
43v SMPS for dual bridge mono LM4780 - Click HERE for Original Thread
juan_caliente
Hello Everyone,
I recently purchased a SMPS from Ebay: http://cgi.ebay.com/ws/eBayISAPI.dl...51981&rd=1&rd=1
I was hoping to use it to power my two lm4780 boards from Chipamp.com.
Has anyone ever used this smps for the dual mono application. I also want to build a drv134 bridging module so that both boards will have a mono output. This is going to be used to power a bass guitar monitor speaker, probably an Omni 10, 12 or 15, for practice with my pc running guitar rig 2.
Thanks for your assistance.
Sincerely,
John
Minion
Well First off that PSU will not supply enough Current for a 2 LM4780...Actually it will barely supply enough current for Half of a LM4780.....
Also +/-43v Rails is actually Too high of a Voltage for the LM4870, It states in the Datasheet that the Absolute Maximum it can stand (with a signal applied) is +/-42v and at that Voltage it will run very hot...+/-35V is Probably the Max that I would use but +/-28v what I aim for.....
If you had one of those PSU"s for each Half of the LM4870 (the LM4870 is actually 2 LM3886 in One Package) then it would work but you would probably have to regulate the Voltages down closer to +/-35v for best performance useing maybe an Off Board Linear regulator......
Good Luck
AndrewT
that ebay site is telling lies.
I see they cover themselves by offering a modifcation to get the voltage down to +-30V.
For 8ohm speakers (not 4 to 8ohm) you can run @ +- 35Vdc.
for 4ohm speakers you can use +-28Vdc.
for 6ohm or 4 to 8ohm probably some supply voltage in between.
You may be able to modify the SMPS to allow either 8ohm or 6ohm speakers to be used.
But the problems go on.
I think a 3886 has a peak output current of 7Apk.
A 4870 has two 3886 inside so the total output current is 14Apk.
Fortunately the supply pins for the two internal amps are separated so you can supply each chip separately.
So four of these SMPS can supply your two chipamps with less than half the peak current that they need.
I would suggest you try to sell on the SMPS to some unsuspecting purchaser, but try to be a bit more truthful.
Then go and buy a proper transformer/rectifier/smoothing capacitor PSU and do the job right.
Each 3886 can deliver upto 60W so the 4 chips need about 1.5Times (60+60+60+60) = 360VA @ 25Vac-0 & 25Vac-0 for 8ohm speakers or 360VA @ 20Vac-0 & 20Vac-0 for 4ohm speakers.
justblair
Can's say much about the SMPS, through ignorance more than anyhting else. However I have used that particular E-bay seller without any problems. In fact just had some lm3875 chips delivered today. Its the second time that I ordered there. Stadholders prices were the best I could find. Got 4 for £9.18 this time, though I did win a pair in auction bought the other two buy it now.
The description does make it clear that the voltages are working at the absolute maximum for the chips.
I looked at this supply, but ended up going for four skynet 8080's.
I was more confident doing this as I could then use Decibel dungeons instructions to build an array i knew would work. I had my teething problems certainly, but i knew that I was not trying to achieve the impossible. I am very pleased with the SMPS amp, I have not built a transformer/rectifier/smoothing capacitor PSU as suggested by Andrew to compare with the SMPS but NUUK has tried both and recommends the SMPS.
Dont know if my experiance helps but I thought I would chip in.
juan_caliente
Thanks for all of the replys. I have spoken to a couple of members here about modifying this smps to work with a single board set, and getting a second smps for the other channel. I am sure it is going to be some work getting it all done, but I think that it is going to be fun to experiment with the smps, rather than the time tested transformer route.
Does anyone know of a good source for 1u and 2u rack mount cases? I am also building a dual channel tube blackface preamp and a acoustic 360+. I need 2 of the 1u for thoes and probably a 2u for the power amp. Has anyone ever made their own using steel from a hardware store cut to size? Mabey bolted to a frame of extruded aluminum?
Thanks again,
John
justblair
I have never made a rack, but I have seen a DIY rack made from MDF on the internet somewhere.
It was months ago when I saw it. But a bit of googling might be worth it. It is likely I saw a link to it through hackaday, cause its the sort fo thing I would have come accross through browsing rather than by looking for. If I recall correctly it was used for mounting a server rather than audio equipment.
Sorry I dont have time to search it out again. I have some heavy work on right now. If you have no joy by hte weekend I will see if I can find it for you.
Blair
space
With some hard work you probably can make the SMPS deliver lower voltages but you can't (easily and economically) make it deliver more current. I would drop that SMPS and look for something with the right spec (~+/-30V ~10A).
space
kscharf
I don't know that I'd want to use a SWITCHING power supply in an audio amplifier application anyway. Asking for noise problems IMHO.
justblair
quote:
No noise issues with mine, silent when its supposed to be. Very detailed, controlled sound.
I have 4 skynet 8080's in series and parrallell to give +/-24v 6a. I folllowed NUUK's advice to make it and I am very happy.
FastEddy
I use two +48 VDC switchers and my own "secret sauce" humbucking torrid line filters to get a really nice quite source. Result is +/- 48 VDC rails driving two 500 watt modular MOSFET amps (into 4 ohms) with reduced power of ~ 220 watts per channel = a very cold running amp for 24/7/365 usage without ever needing a fan ... This one is a work in process ...
AndrewT
Hi Fasteddy,
500W into 4 ohms from +-48Vdc supply rails.
Are these amps bridged?
FastEddy
Make that ~ 250 watts from each amp module / each channel = ~ 500 Watts in total output. Yes, these can be combined or bridged, but for the purpose, not.
(The alternate configuration, +/- 60 VDC from dual 60 VDC supplies is closer to the total "One Horse" configuration = ~360 watts per channel = ~ 725 Watts if bridged = ~one horse power.
From the module maker: http://aussieamplifiers.com/nx500ln.htm =
Specifications
500 Watts RMS into 4 Ohms RMS Min Continuos
300 Watts RMS into 8 Ohms RMS Min Continuos
Frequency Response: 5hz to 200khz
SIgnal to Noise Ratio -125db) ... )
It's quite possible to like the sound when it's powered by a SMPS. There's another factor, that the PSRR of these chipamps drops quite a lot when dealing with high frequency noise like any switcher will generate. For example the SMPS might switch at about 50KHz and have a quite broader band but to focus on 50KHz alone, PSRR (V-) is already down from ~ 120dB to 45dB.
Given enough time and a scope, appropriate filters could be made to mitigate this, but in general the noise is approaching something audible from the amp.
I'm not saying a SMPS can't work, only that unless you are actively seeking to alter accurate amp output, it is technically best to stick with the traditional low freqency supply then if you want to tweak that, put more filtration like a linear or cap multiplier stage in it.
I suppose what I'm really getting at is if someone had a beefy switcher and wanted to save some $ or just play around, it makes more sense to try it than for someone who has yet to buy a supply and isn't looking to alter the expected sound of a gainclone.
justblair
I didn't understand much of that !. Suppose I were to go the low frequecy supply route... Would my sound get better? Its already very good, but I am open to suggestion. NUUK on his site reckoned to the SMPS being the better sounding option. I'm a mere sheep on this one. I was building my first, I just copied the easiest to understand site I could.
I can understand the PSRR is reduced (I'll take your word for it...) but is it not reduced enough not to be an issue anymore? I'm trying my best to learn but as you can probably tell I have a bit to go...
Blair
Above "down from ~ 120dB to 45dB" is wrong, should have been roughly ~ 100dB to 45dB, drop.
justblair
What effects would this have... I know I'm asking dumb questions... But I dont know why they are dumb :xeye:
Is there something in the sound I should be looking for?
Thanks for your patience
Blair
Obviously audio is a subjective thing. I can't tell you what "sounds better" to you. I can instead tell you that SMPS introduces distortion and I think most people will tend to want to avoid that, [I]while[/I} striving for the sound they like. In my opinion the first gainclone one makes should not use a SMPS, and then if one wants to swap in a SMPS to compare the sound, with the same or an identical amp, they will understand more how it effects the sound. I also encourage such tests, including linear regulation of an unreglated supply instead of or in addition to the SMPS trial, but I think it only fair to start out with the known universal an technically correct way to get the best agreed upon, and measurable, sound, which is not using a SMPS. After you achieve that, you have a frame of reference to what others are referring to from similar gainclones and can better contrast changes from SMPS trial.
Blair
I don't know what you're trying to say with your double negative statement.
You don't want PSRR reduced at all, ideally it is as high as possible on any amp. It is bad for it to be 45dB @50KHz "IF" the supply is at 50KHz (which it may not be, but in roughly this 20-100KHz range is likely and the PSRR drops quite a bit more as frequency climbs). It is an issue. Clean power is part of the reason why some amps sound different, sometimes better, than others.
All I'm really saying is, you owe it to yourself to hear what the amp was meant to sound like before adding or changing things that have a strong potential to interfere with fidelity. This is not a new topic, SMPS are known to be a bad thing to use for an amp for many years by the overwhelming majority of audiophiles. Its only a certain niche thing, if you like what it sounds like. Most people apparently don't.
Blair
You should be looking for a non-SMPS so you can hear the amp without it being distorted by the power supply.
Then you know what you have for an amp. If it doesn't sound right, adding distortion is usually not the answer unless it's getting a signal from an electric guitar, or it's a certain type of distortion like from a tube preamp.
The answer is do not use a SMPS. Build it correctly first then listen to it. Now after you have listened to it in it's technically correct form with as little distortion as possible, then add the distorting SMPS and listen again.
There's no words that will do as much as just listening. I advise NEVER EVER EVER to build something with a SMPS the first time. Only switch to a SMPS temporarily, do not do the wrong thing then ask about it, do the right thing the first time so you know what you were supposed to hear, what the amp sounds like when it's not being distorted by the PSU. I can't subtractively tell you what noise to ignore or how much of a factor the amp design was in what you hear because these are variables.
justblair
Hmmm
I will perhaps try a normall one in the future, fortunately I like the results I have so far, So I can try out other stuff later.
NUUK though does seem to prefer smps, so there is one or two different opinions there. (isn't there always!)
Thanks for the explanation... Even if I only half understand it probably.
Blair
If it's opinion, one opinion is held by the vast majority in addition to being technically correct. SMPS is considered a very bad thing to power an amp with by the entire world of audiophiles except for a very few who either sell SMPS, finished products that were cheaper because they used a SMPS, or those who have never heard optimal versions of both PSU types.
Cost or space and weight constraints are the only real reasons to use one. Deliberately causing the power rails to be dirty instead of using legitimate audio-related changes is like rejecting everything you were trying to learn and achive and just spinning the wheel of chance to see if you are lucky.
Reasons to promote use of SMPS is another matter, anyone who is selling SMPS might promote them for uses even if they aren't good for the purpose. There are only a handful of people who really seem to think SMPS seem ok. Nuuk is one of those very few and just happens to hang out here, so you are getting a very lopsided perspective. Nuuk may honestly prefer the sound of SMPS, but most people do not and Nuuk should know well enough to make that clear to anyone before having them only hear a distorted amp without a way to hear what it was supposed to sound like.
Given this supply with too high a voltage and too low a current, I suggest that if you want to use it, you try a capacitance multiplier circuit. It will increase momentary energy stored from the transformer, decrease rippple, provide higher current (depending on what the drop is, lower being even better). If you had an LC stage inbetween the SMPS and capacitance multipler, even better. If you wanted to set a *regulated* voltage via the multiplier circuit by including a zener diode, that would work too. However, unlike (in a basic config, the bare transformer and bridge rectifier plus smoothing cap) an unregulated PSU, trying to stretch a SMPS beyond it's current capability can have ill effects. It might shut off. It might fold back to a lower voltage, which is fine if only a moderate amount and if behind a filtration stage,
For example,
http://www.tcaas.btinternet.co.uk/jlhcapmult.htm
I would not aim for least voltage drop from a cap multiplier though. As others have mentioned, the PSU is more than a little light on current so IMO you should shoot for a more significant voltage reduction. Perhaps 30V is more suitable but to be frank I would think about re-ebaying the PSU and going with a more conventional method. I've built capacitance multiplier regulation boards for a gainclone and the board was as large as the gainclone itself, at some point you have to pause and think "it is going to be better or just take a lot longer". Capacitance multipliers are not necessarily a bad thing, but better seen as an improvement on an already adequate supply, rather than a way to try to stretch a supply with only a fraction of the needed current to a level beyond their design.
However, my last few words opened a whole 'nuther can of worms. Given time to reverse engineer the SMPS, it is possible to tweak it to get a lower voltage but higher current at that lower voltage (within limits, don't try to halve the voltage or anything near that). For example if you hacked a +-42V PSu to output only +-32V, in "most" cases it would stay stable and have a little higher current. To "some" extent, a SMPS is VA limited, if you dropped the voltage 20% you may increase current by 20% (if it's well engineered, you have to check on current ratings for cerain parts after the transformer like the diodes, but frankly if they are that close to their margins already, it's not a SMPS you'd want to use long term for an amp). 20% is not much, but suppose you got closer to your target voltage, say that target was about 32V and you lowered the supply to 36V by hacking it. A capacitance multplier might do pretty well in that scenario.
I don't really mean to encourage it though, this is more of a stuck-on-deserted-island-pnly-have-one-PSU, perspective. Ideally you just want a transformer with lower voltage and more current, then decide how elaborate the PSU is after the rectification and filtration.
pocketman
Don't feel bad I purchased two of the same units from ebay on their word that this will work. i wish I had seen this thread BEFORE i purchased. Where can one find a +/-35V toroidal transformer to use with a set of lm4780s?
Dean
Arx
It's probably not that hard to convert the voltage.
I've done it with old computer power supplies. There will probably be a feedback voltage drawn from a voltage divider on the output going back to the PWM controller. They work by increasing or decreasing the pulse width to match the feedback voltage to a reference voltage.
Usually if you're only trying to drop the voltage, all you have to do is change one of the resistors in the divider such that the output voltage of the divider will be correct when the amp is putting out the voltage you want.
Going higher in voltage is tougher, because you usually need to modify some overvoltage protection circuits as well (usually just replace a zener)
I'm not a total expert on it, but I've redone the regulation to give me a solid single 12V output on a few ATX supplies. Also upped one to 16V to replace a missing supply for a laptop I bought for cheap in an auction.
It's definitely doable if you're willing to figure out how they work.
And as ! mentioned, they do tend to be capped by the VA rating of the transformer, assuming there's enough margin on the output diodes and chokes, so you may be able to eek out a little more current as well.
I'm not saying it's a good idea, but if you can't find a good home for the supplies, it may do a halfass working supply. You certainly won't get full power out of it.
You may find it shuts down when a heavy bass note hits, etc.
If it's too cheaply built, you may just blow out the choppers from all the stress.
But I think there's probably still a lot of unrecognized potential in switching power supplies in audio stuff.
They've gotten a bad name in the past, but possibly just due to bad designs. When transistors were first invented, they built some pretty wretched amps with them, but these days people have figured them out pretty well.
-Nick
alleycat
Has anyone tried the techique used in this article?
http://www.acoustica.org.uk/t/3pin_reg_notes2.html
Looks promising.
quote:
Originally posted by Arx They've gotten a bad name in the past, but possibly just due to bad designs. When transistors were first invented, they built some pretty wretched amps with them, but these days people have figured them out pretty well.
-Nick [/B]
This is pretty much false. The advantages of a SMPS are (sometimes) lower weight, sometimes smaller size, usually greater efficiency, sometimes lower cost, often lower weight.
What a SMPS practically never does, is offer the same clean output. The primary difference we are all interested in, in a audiophile forum, is not typically size or weight or efficiency, it is that given practically any (every) design, the PSRR factor is far far worst with a higher noise frequency necessarily present in even very well filtered SMPS. Above all else, high frequency noise in the supply is a target for elimination!
SMPS have no place in audiophile land, they are always a concession that goes against fidelity. If you "like" the coloration caused by their noisey output, good for you, but there are so so many different ways one can degrade output and still say they "like" it, that we can still chaulk it up to a subjective impression that should not be assumed as a goal.
The FACT is, a SMPS cannot perform as well. There's no "good design" that changes this, unless you're only arbitrarily contrasting with a "bad" non-switching design which is not a fair comparison.
Arx
This is a pretty closed minded view of things. Nothing I stated was "pretty much false" I just stated that I think there's potential in them and that their problems were
possibly just because of bad designs.
I for one am willing to experiment.
A smaller, lighter, more efficient supply seems like a good idea to me, and I don't think that the problems are insurmountable. If you can explain to me scientifically that I'm wrong, my theory will change to align with your "FACT", but I don't think you can.
If this kind of thinking isn't allowed in your "audiophile land" I'll just pick up my power supply and go hang out elsewhere. (I can do that, It's much lighter than your big transformers)
Maybe science land. Scientists are all about learning new things, and changing theories as new information dictates.
Back to my previous analogy. If there were internet forums back when people first started playing with transistors, I'm sure someone would be saying the same things about them, and yet today the general consensus seems to be that they're a pretty useful technology.
-Nick
FastEddy
alleycat's post above is interesting and then some ... Yes, this works. :smash:
alleycat: " Has anyone tried the techique used in this article?
Looks promising. ..."
Arx
Alleycat: Agreed. A very interesting post, especially since the bass amp I'm currently working on will probably be fed from a switching supply based to some degree on a computer supply. Either converted from one, or built out of all the parts from one.
-Nick
pocketman
Nick
how many of these gainclones have you made up? have you done any with SMPS? It says you live in North Van. WEould you be willing to give me a hand on getting mine to work?
Dean
Arx
quote:
Originally posted by pocketman
Nick
Dean
I'm working on number 3 at the moment, though I still haven't finished the chassis for #2 yet. I'm far from being an expert at it, but I'll certainly be willing to lend a hand if I can.
#1 Is one of Peter Daniels' kits. Definitely an easy way to get started for a beginner.
#2 is a 6 channel which I'm using for tri-amping. I finally got around to picking up the caps and hooking up the last 2 channels a few days ago. So far, so good.
#3 will be a bridged parallel LM3886 bass(guitar) amp, though it's probably still a while off. I'm working on the PCB layout right now.
-Nick
quote:
Originally posted by Arx A smaller, lighter, more efficient supply seems like a good idea to me, and I don't think that the problems are insurmountable. If you can explain to me scientifically that I'm wrong, my theory will change to align with your "FACT", but I don't think you can.
If you prefer the size or weight more, that's certainly your choice to make. It's a choice of those instead of higher quality audio. I already explained why, but you seem to have ignored the fact which goes against what you wrote below.
Actually my view is scientific, the scientific method does show the noisier output in high frequency range directly conflicts with far worse PSRR at HF of audio amps.
-Nick [/B]
You seem to be suggesting switching PSU are "new" or something. There is good reason why it isn't common on good equipment and it is nnot that nobody tried, it's that it doesn't work as well. One of the goals should always be matching the qualities of the supply to the requirements of the load. If you have other requirements for your aamp that supercede the audio output quality it would be seen as a departure from our core goals, except for the generalized goal to DIY and experiment.
You might actually prefer the distorted sound produced by using a switching supply. Some people also prefer the sound of distortion caused by tube amps. The difference is there's a scientific backing for the latter having even order harmonics, while the former tends to just introduce an ever increasing random error rate as the audio frequency rises. You could do a lot of work engineering addt'l output filtration for a switching supply to (mostly) overcome this, but as you do so, the cost, size, weight increase which goes against the point of using one, and the addt'l complexity rise makes it a shorter lived amp. To some a ~ 10 year lifespan might be acceptible but generally it is accepted a switching supply has a shorter lifespan and if an amp is good, it should be timeless, worthy of listening to 30 years from now.
There is one other good reason to use SMPS, to make it more energy efficient, though it wouldl only follow that the amp is then some derivative of class D instead of A / B.
Arx
I expect your power supply will likely need some new caps within 10 years too. That's really the most likely part to fail in a switching supply as well. Sure, the output transistors may fry when the caps do give out, but I'm willing to spend the extra couple bucks when the time comes, if I ever let them get that bad.
I may switch to class D at some point, it makes a lot of sense. I don't know enough to make a very good class D amp right at the moment, though. Chipamps are cheap, easy, and still reasonably efficient.
Not every design needs to be on the extremes, and people may have different design criteria. A big part of the reason my current amp will have SMPS is for weight and size, so I'm simply choosing a different balance.
Maybe some people are more concerned with efficiency. Obviously SMPS don't make awful sounding amps, or people wouldn't say they sound better than their linear supplies. I'm not saying they sound better either, but there many criteria involved, and it's easy to get stuck on one. Perhaps the linear supply has some downfalls which you haven't considered which contribute to these people liking the switching supplies more.
Just because the supply has more high frequency noise on it, and people like the sound of it doesn't mean they like the noise. There could be other factors involved.
Why do people listen to vinyl? Do you think they enjoy the clicks and pops?
Personally I think it's all a bunch of ****. I doubt I could hear the difference. Nor could a large percentage of the people who claim to, given a double blind test.
-Nick
[B]
No, this was specifically why I mentioned caps. The lower frequency in a non-switching design allows much longer life from same quality caps.
Chipamps are only as efficient as you choose to make them. You might do class A/B to some extent but so you could with a non-chipamp, though class A isn't out of the question if a modest output power.
You can DIY a class D if you want. The sound quality is something many will argue about but I think most people will agree they're good enough now to not only be reserved for driving a sub anymore. There are some nice premade kits at 41Hz.com to serve as an introductory project.
Fair enough, if all amps were the same it would be incredibly boring?
This is the crucial bit, that they are liking the change it makes to a lower fidelity sound. Everyone is entitled to have their own preference, but there are so many ways to change an amp and IMO picking a suboptimal PSU type is not the answer unless they have the other criteria as you mentioned.
If they say it sounds better, I think we do have to concede they are liking the noise... since it is PSU noise and that modulates the output sound even too fast for an amp with a feedback loop to correct to a high degree.
I think it's because that's the medium it came on, the medium on which they first heard song "X" and they became accustomed to it sounding like that and want to recreate the same sound. However, I think no so many people do listen to vinyl anymore, many who formerly did have digitized their collection.
pocketman
I really am new to this building amps thing. I built a 3w tube amp as a project in school, which was cool, but even then it did not compete with the detail of the discrete amp that I bought. The reason I am building one now is, I wanted to see how these chip amps compare to the amps that one can purchase.
I need either a 4 or 6 channel amp to run my dedicated 2 channel system which uses a digital crossover. Many of the amps out there are over $1000 and a 6 channel chip amp should come up at half of that.
The switching power supply intrigued me it was cheap to purchase and efficient and supposedly does not have a 60Hz hum, which I thought would be pluses.
At this time I cannot make the amp work, however I need to check if its the power supply or the amp. I do not really know how I am going to do this yet , as I do not have test equipment.
I have been interested in audio for the past 30 years and I have been able to hear the differences of many of the technologies that have come (and gone). I eventually think that digital amps are the future, its just I am not able to afford a Millennium amp.
Page generated in 0.13645195960999 seconds with 17 queries,
spending 0.00938702 doing MySQL queries and 0.12706494 doing PHP things.
