diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Question about the CC shape in A126 - Click HERE for Original Thread
FlorianO
While my build for A126 is still on ice -- after 3 weeks I still haven't got the drivers, they apparently got stuck in the customs -- I have a question about the shape of the CC in A126.
Since we need to extend the top back of the CC to get to the recommended 2.2 liters volume, its shape changes from that nice triangular profile to a stranger, elongated shape.
My question is if the _shape_ of the CC is important in any way.
TIA,
Florian
ronc
Yes it is. I dont believe in flat panels which reflect a wave back to the driver. My original idea was to reflect the wave thru an absorbant medium at the rear of the chamber.That or an object that would disperse the higher frequencies.
Simply line the rear of the extended chamber with 1/4"T balsa with a thin layer of felt on top. The area in the rear would be 1/4 the length of the chamber.
ron
FlorianO
Ron,
Many thanks for chipping in
quote:
Only the top part ike in the attached picture of Dave's modified CC ? (With the corresp. volume correction, of course Didn't have a better image at hand) Or both that part and the bottom sloped part (i.e. the part sloped towards the exit of the CC) ?
*Ahem*.... Not sure I follow...You mean the lining should go for the whole width of that part (i.e. width of the front baffle) and for a length equal to 1/4 of the "max depth" of the CC (when seen from the front baffle) ?
FlorianO
Ron,
Since I got your attention, another quick question:
Another possible way of increasing the CC volume up to the recommended 2.2 liters is by extending the CC upwards like in the attached picture.
Any preferences compared to the above "elongated" CC ? Lining of the back of the CC in this case (as per above) ?
Thanks again,
Florian
FlorianO
Or like this, parallel with the front baffle ?
ronc
The first image is correct but all around the rear of the CC. The idea is to reflect as much of the wave as possible thru two different mediums. The first medium has a lower density than the second, this provides for a greater BW of attenuation as well as greater attenuation of the higher frequency waves.This is termed "progressive attenuation".
Example! Ever see the grouping of barrels on the median of an off ramp on a freeway? The first set of barrels are filled 1/4 with water,the second 1/2 full and the third full. This allows a progressive damping of the forward mass/velocity of the auto.
ron
johninCR
Florian,
My suggestion is that if you are willing to spend time tweaking, make the CC larger than recommended. I did that with my Frugel's, and found that not only does the shape and volume have a big affect on sonics, but so does what you choose to fill it with. Interestly, I discovered my favorite combination while I was exploring only different volumes. That included cans of refried bean paste as fill with only minimal foam rubber to ensure they didn't rattle together. Not only did it diffuse reflections nicely due to the shapes, but the cans were sonically dead but rigid, and I found angled pieces of plywood and mdf to result in sound more muffled and dead.
FlorianO
Ron,
Many thanks for the explanation
John,
Thanks for the advice...If I follow Dave's CC (first picture above) the CC volume computes to 2.9 liters. As pointed by Dave himself that is above the recommended volume (2.2 liters) and he had to stuffed it with corrugated wood. However, Ron disliked the idea of stuffing. OTOH lining parallel with the back walls of the CC seems to be it.
Wrt shape the choice is either extending the CC backwards like Dave did, or maintaining the triangular profile and extending it upwards. In the latter variant, if I extend it all the way such that the top sloped back of the CC becomes flush with the front baffle the CC volume gets up to around 2.0 liters. Getting up to 2.2 liters from there can be done in two ways:
- Adding the suprabaffle and accounting for the cut-out in the front baffle (added voulme is 0.177 liters for a circular cut-out of 56mm radius, like in Daves PDF).
- Additionally pulling the back of the CC backwards, like above.
OTOH Rons dislike for front panels reflecting the wave back to the cone this seems to discourage the idea of extending the CC upwards, and Dave's way may be better. Unfortunately I cannot find any information wrt CC shape in BLHs to get some guidance to what effects one should expect from either (sharp corners from triangular profiles vs more 90 degrees, rectangular-ish ones) but seems to be a matter of trial-and-error :(.
ronc
but seems to be a matter of trial-and-error .
No it is not. I do a wave form on the chamber and attempt to find the most effective ,simple way of attenuating the higher portions of the FR. The problem is to make it simple to the average builder.
There are two basic ways of wave attenuation.,dispersion and absorbing.If you study the wave pattern of the original designed chamber you can see that the wave fronts are reflected at two points, if there is a progressive attenuation at these points then the energy is reduced. The wavy wood is a dispersion, but if it was me the ridges would be of a random height and width between the ridges.On one of the designs , i believe it was the adjustable volume method, there is a styrofoam tube at the rear of the chamber where the energy is concentrated.
Now the most effective is to have all four sides of the chamber reflect the positive wave rearward and both diffuse and attenuate the wave. However now you are talking a complicated build.As has been stated by many before, a horn is a series of comprimises. I attempt to make the build as simple as i can any at the same time have good performance . The Dallas is a good example, its a very complicated build and i am sure if i had the Austin programming at that point it would have been a more simple design with the same or better performance. One of the more difficult design parameters is total use of the internal volume. The Austin has a very small waste volume at the mouth exit and again in the deflector, but otherwise the volume is totally used.
ron
( words of my old engr prof "the hardest thing you can do is to make something simple")
FlorianO
Ron,
When I meant that it seems a trial-and-error process I was thinking about the impression I've got from other builders, not the designer himself :). IOW _I_ couldn't find material -- other than your own brief descriptions -- with insight in the design of the CC (and, by extension, the horn itself).
Your input confirms my interpretation that Dave's build was actually better wrt back reflections whereas extending the CC upwards had -- in my simplistic view of wave reflections -- had same type of back reflections towards the cone _but_ had one extra sharp (i.e. 45 degrees) corner at the very top where energy could concentrate.
johninCR
Florian,
It shouldn't have to be trial and error, because apparently there is a program that can tell us the size and shape needed to attenuate a given frequency range. Think about talking into the big end of a megaphone. How small can we make these conical shapes and achieve the same effect? I think this info would be quite useful in speaker building and room acoustics, however, the program has some military application and not avaiable for our use. All I want is the dimensions and shape for say 250hz and 80hz.
FlorianO
John,
Well I don't see how that comparison holds. AFAIU Rons post above the CC should ideally have a low pass characteristic before passing the energy into the throat of the horn (a low pass itself).
Actually Ron's suggestion of following the wave expansion/reflection pattern in the CC got me thinking. While I do not have at hand any tool for accurately simulating wave expansion and reflections, it was really helpful in thinking about the CC in terms of expanding waves. In that respect a way to expand the CC while (somehow) maintaining the shape Ron designed is to "push" upwards (resp. backwards) the top (resp. the top back) of the CC at the same "rate". A quick, back-of-envelope computation of a CC expanded that way gets to a total CC volume of about 2.0 liters. Adding the suprabaffle should raised that to the total recommended.
Unless advised otherwise I'll post picture of the profile and the resp. dimensions.
Maybe I'm beating this subject to death but I don't want just to follow some building plans, but also understand what I'm doing (well, as much as possible :))
Florian
johninCR
Florian,
Yes of course the CC volume and throat dimensions determine the acoustic low pass filter for what enters the horn. It's not a perfect filter though, and location of the throat, it's shape and orientation, will also affect it as a low pass filter. What about the rest of the frequency range that comes off the back of the driver? It has to get dissipated as heat, reflect back out through the cone, or sneak into the horn. When you add damping material to help dissipate it, you change how the air volume behaves.
That's where your original question is right on target. I'm convinced that the shape of the CC can go a long way toward helping it form a better low pass filter for what enters the horn, and also help reduce the potential for reflections back through the cone. Unfortunately the program that could help tell us the optimum shape and dimensions has military applications.
FlorianO
John,
Yes, that CC shape is important I suspected from the beginning and hence me asking. Still, my original (and subsequent) questions were more on the _hows_ i.e. are there any guidelines, even generic ones?
Ron kindly uncovered a few: no flat surfaces that directly reflect back the back wave to the cone but instead try to reflect the wave away from it, no sharp corners (?), think in terms of expanding waves. But I guess the most important was that a design has to make compromises with practicalities (easy shape to build, etc).
johninCR
Florian,
If you find a guideline, please let me know. Ron's the only one I've see who even attempted to address the issue in his design with the angled CC panels directing reflections at a styrofoam plug behind the magnet. I liked the version the Planet10 & Chris used early in the A126 process with the CC curving and tapering to a point. Those may even be the speakers that Dave still uses.
planet10
quote:
I'm running low on FE126e (fresh batch ships in a couple weeks) + we are starting a series of FE127 based cone mod tests so the newly revised diyREF bipole ML-TLs are in the system.
dave
FlorianO
[B]Florian,
That's exactly why I bothered Ron with so many questions and wanted him to comment on the different CC shapes :)
The more the better :).
On a more serious note: Many thanks again Ron !!
ronc
Its no bother. Just sometimes i get involved with projects other than audio so i hope yall understand.
I could sit down and design a HF trap/CC and probably lower the energy> 95%. However it would be a complicated build. Then how many would actually use the design.
In any design of anything you try to arrive at a point of pratical application which is a balance of cost, ease of build and performance. The more detail, the more cost and difficulty of build that has to be weighed aganist the gain in performance. You can drive to the store for a gallon of milk in either a Yugo or a Porshe,both will do the task but at what difference in cost and if the speed limit is 35 mph then what is the actual gain difference between the two?
ron
johninCR
If I can build it myself, I'll take the Porshe in a heartbeat.
FlorianO
Now I'm getting nervous: Comparing A126 with a gallon of milk...
Florian
serenechaos
Given the choice, I'd build & drive the porsche every time, no matter how slow, or how much work it was to build.
BTW, thanx again Ron for the continued input.
I built a pair of Austin 166s, and of the many speakers I've built/heard, they really are the best.
Enough so that I'm inspired to build a pair of A126s for a small room.
FlorianO
Good to know. Much better than a gallon of milk :p
Especially since my modified CC now resembles the A166's and has a vol of 2.1 liters ;) (see below)
I've now got my drivers and hope to get thorugh the build asap. As promised, I'll document it in the A126 for the metric freak newbie thread :)
Page generated in 0.060076951980591 seconds with 17 queries,
spending 0.00896645 doing MySQL queries and 0.05111051 doing PHP things.
