diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Where to get replacements for A1265 and C3182? - Click HERE for Original Thread
turbo_slug
I have a yamaha ax-440 that has two blown output transistors.
Anyone know where i can get replacements? Are there any other transistors that will be suitable as a replacement?
Stuey
These people have them.
http://www.wagner.net.au/Welcome.htm
The only issue is that they're in Australia, but I can vouch for their excellent service. Unfortunately they are a bit old fashioned and haven't quite got their site up and running in a modern fashion! Very good for prompt delivery, though. I usually fax an order; I know it's a bit of a pain, but still... There's a fax order dowloadable on the site.
I recently bought two each of transistors similar to yours (A1263 C3180) which I can vouch are genuine Toshiba; or at least look absolutely identical in quality to the originals.
You can download a PDF catalogue - they have a massive range of hard to find transistors. I also got some Rohm transistors which were practically impossible to find elsewhere.
I've checked and yours are listed.
Cheers
Stuey
turbo_slug
ok, i found some A1265 and C3182 at a local store...
the original parts in the amp appear to be toshiba parts but i dont think toshiba makes them anymore...the ones at the store were made by some unknown manufacturer but they were faily cheap ($2.50 each). are those parts worthy of being used?
the amp is an old yamaha natural sound ax-440 i got for free. i dont think the amp is worth more than $50-$100 if it was working. should i bother to track down the original parts?
Stuey
So what am I; chopped liver? :D
Page generated in 0.021492004394531 seconds with 17 queries,
spending 0.00842857 doing MySQL queries and 0.01306343 doing PHP things.
