diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Perpetuum-Ebner PE66: To fix or not to fix... - Click HERE for Original Thread
Grendel the Cat
Greetings,
I have a Perpetuum-Ebner PE 66 (inside an early '60s Schaub-Lorenz Ballerina 20) that has an idler wheel in wretched shape. I'm torn between making a new one or having one made vs. finding a way to amplify the signal from a modern turntable (which, naturally, would be kinder to vinyl than those older ones).
--This stereo console has a round, radial-pin style input for a tape machine (5-pin) and the 3-pin "in" for the supplied turntable unit.
I've seen the other postings regarding the idler wheel replacement options, but I'm still looking for suggestions.
Thank you.
Eric
Seattle, WA
U.S.A.
Page generated in 0.01869797706604 seconds with 16 queries,
spending 0.00982475 doing MySQL queries and 0.00887322 doing PHP things.
