diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Help, Foxtex Fe207E FE206E hole size - Click HERE for Original Thread
OzMikeH
My FE207E drivers are taking a long time to get here, I want to cut the holes in my cabinets for them.
The Foxtex literature says 185mm cutout is required. Can someone measure a driver and verify this for me please?
I had a bad experience with a JBL driver that stated a hole size on the literature that was actually 7mm bigger than the required hole. I had to start again with the front baffle for that one.
Has anyone made a cabinet with these drivers and cut the hole at 185mm instead of making it to fit the driver directly?
Can I trust the fostex datasheet?
OzMikeH
Anyone...?
<waves router in the air eagerly>
ttan98
"My FE207E drivers are taking a long time to get here"
there is a local distributor in Australia... the name is
http://www.majormusic.com.au/
cheers happy lisening..
OzMikeH
Yep, they are who I used.
They were very good, the speakers were dispatched from Sydney on Monday. they didnt make it here by yesterday so I wont see any until at least tuesday, probably wednesday.
I just want to make sure I dont cut too big (or too small) hole in my cabinets. I want to start sanding and painting them in the next few days so I'd like to cut the holes before the drivers arrive.
Scottmoose
I don't remember needing to make alterations to any of mine, despite using the driver information. Fostex designed them, so their measurements tend to be quite good... ;)
OzMikeH
My drivers arrived, Horay!
I didn't expect that on Good Friday (A public holiday here)
183mm with a very slight chamfer
impressive build quality. I haven't used Fostex drivers before.
the screws that come with them look pretty cheap though, I won't be using those.
Page generated in 0.15178203582764 seconds with 17 queries,
spending 0.13487697 doing MySQL queries and 0.01690507 doing PHP things.
