diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
lm3886 clicks when turn off - Click HERE for Original Thread
Williams Audio
Hi all,
the amp works fine but when turn off clicks very badly.
during turn on the mute circuit is working nice, there is any trick to turn it off with out clicking,
I mean by activating some how the mute circuit.
Thanks a lot and best regards
Williams
SpittinLLama
Are you running from a bench supply or a full amplifier with it's own supply? The sharp click can be from the switch. Try a 0.1uF ceramic cap across the switch terminals rated at 100V or more. That should remove the click.
-SL
Williams Audio
thanks for the idea, i will do it.
best regards
williams
Page generated in 0.019893884658813 seconds with 16 queries,
spending 0.00974774 doing MySQL queries and 0.01014614 doing PHP things.
