diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph 3 R114 connection - Click HERE for Original Thread
Forte
Does the connection point of between R114 & C103 have connected to Q105-E?
I just saw one article in Chinese say it have to connected. But compare to Aleph 4, I think maybe not.
tortello
No, it must not be connected to the Q105-E.
"...R114 and C103 adjust the current
against output current as sensed by the voltage across R124-127...."
Nelson Pass
When I draw a schematic, I follow the standard where
two lines crossing are not connected unless there is
a big dot on them, and I don't even use dots. Connected
lines form a "T".
Thus R114 does not attach to the emitter of Q105.
There is some confusion on this as the Aleph 4 schematic
had an error in it at the junction of C9, R26, R28 and
the base of Q3. These are all connected at this point,
and corrected schematics shows a big dot there.
The same error made it onto the Aleph 5 schematic, where
the base of Q5, R19, C10, and R20 should be connected
with a dot. This was the result of "cut-and-paste".
The Aleph 1.2, Aleph 2, and Aleph 3 schematics are
correct in this regard.
Forte
Thank for the answer. It¡¦s helping a lot.
I have another question related after these few days. The sequence of R114 & C103 makes difference.
I found in Aleph Design have two setup. Resistor come first from Output, some time is Capacitor. And sounding little difference by listen some music. I like Resistor first from output. Just like Aleph 4 & 5. It seems to be more Clearly & Purity.
Why there is two kind of setup is my question?
Nelson Pass
As the two components are simply in series,
there should be no difference whatsoever.
Page generated in 0.020705938339233 seconds with 16 queries,
spending 0.00835967 doing MySQL queries and 0.01234627 doing PHP things.
