diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Let there be music :) ...and Hum :( - Click HERE for Original Thread
sansbury
So the good news is my BrianGT dual-mono gainclone is making music. The bad news is, she is also humming a bit. The interesting part is that there is a lot more buzz in one channel than the other.
All parts including the toroid are in one chassis. Input is a dirt-cheap CD player but the hum comes when nothing is connected so I don't think that's the culprit (though I can for the first time hear how bad it is). No volume control at this time--was going to build a preamp/buffer to go with it.
Grounds from the amp boards are all tied to a central point on the chassis ground which is tied to safety earth.
The wiring inside is admittedly a bit of a dog's breakfast. The chassis is a bit tighter than I expected and I decided to "just get it running" first and then clean it up. As a result the power off the rectifier boards and the signal lines cross around each other a bit here and there. I will post a picture later for everyone to laugh at.
One thing I noticed right off the bat was that the DC offset was different on the two channels- ~95Mv on one and ~65Mv on the other. The buzzy one has the lower offset.
When I first assembled it, I put only one channel together to make sure before blowing anything up. That channel (the 95Mv one) had a little hum, but it was the second one where it got a bit louder.
I don't have a lot of room, but by pushing things around inside I can get the hum to change a little. I pushed a little too hard and made some sparks between power and chassis, but the guardian angels took pity and did not seem to allow anything to fry. I don't expect to get lucky again.
Is there anything in the offset differential between the two channels that points in any particular direction? I'm ready to re-do the chassis in a larger box for other reasons, but I wouldn't mind fixing this one first just for the educational value.
Oh, and this is hooked up to a pair of freshly-made One Pi speakers (8 ohm). Hum aside, the whole setup is still listenable at normal volume and very pleasantly surprising. I have friends with very good and expensive systems, and this ~$400 setup really gives some of the same sensations for 5% of the price. If I can get the hum out it will be a real beauty.
owen
Hey dude, havent given up on ya yet...
Those Offset voltages are on the high side, and how hot are the chips getting, as I suspect that we have some parasitic oscillation going on.
Could you post some pictures of your set-up in the gainclone, so we can see what's going on..?
Owen
PS - could you turn on the function to accept email from board members - I need to send you some details so that we can get you pre-amp working!
Mayday
My chipamp of the exact same kit is also humming a bit, not noticeable when listening to music though. I have choosen not to use the optional caps on the output, I have ca 80mVdc on both channels.
owen
I had tiny offsets (19mV and 12 mV), but I do match all resistors as close as I can manage...
Owen
sansbury
OK, and here comes the ugly duckling... I tried to use wire colors as consistently as possible:
Green: Safety earth (star is in the lower RH corner area)
White: PG- or Signal Ground (L and R)
Black: V-
Yellow: PG+ or L In
Red: V+ or R In
Heat sinks are TO3 with fins hacksawed off. Chips are insulated variety, and I haven't cranked it, but the heatsinks get slightly warm, but not hot, subjectively speaking...
Leads are a mess, I know- I left them a little long at first so I'd have some slack to work with to figure out the chassis layout. Nothing has been screwed down yet. The case is 12" wide and I think I may go back to the shop and get the 15" or 17" one and then I can group things around better, but if I can make this chassis work well I'd be happy with it.
owen
First things first.
You should twist the input cables together for each channel (i.e. hot and ground for left channel twist together), and do likewise for the output cables.
This will clear the field of view.
You also have a ground running from the PCB to the inputs, and from the PCB to a central ground point, and grounds from the PSU PCB to your gainclone PCB. This should all be conneected to a single point per channel, and that ground reference taken to a star ground using a bypassed 100R resistor (take a look at the schematic at decibel dungeon), to connect to the chassis ground.
These two measures alone will significantly reduce the opportunity for induced hum in your amp, and will be a good place to start.
Ok?
Owen
Ps. you can email me at owenanti423spam at netscape dot net (remove the anti, the spam, replace the at with @, and the dot with .). I'd like to get your preamp sorted ;)
jleaman
I would also like to add. See if you can remove the psu boards away from the transformer those are really close. Try organizing the inside of the case so you can have the transformer away from every thing if possible. Maybe get some copper shield. Do twist the wires like owen said. The wire you have is good but twisting it will help alot. If stil huming let us know we are all here to help you.
J'
sansbury
Owen, I will try those suggestions. Will need to review the DecDun site a bit more but I think I have the idea.
As you can see, the case is a little bit tight, so we're talking tradeoffs here. In order to move things away from the toroid, I'll need to move the amp boards and rectifiers closer to each other.
If I get a larger chassis, is there any ideal spacing guideline to work around? Where is the tradeoff between more air gap versus lead length?
jleaman
From your picture you could move the amp's on heat sinks in parallel and then move the psu boards side by side. That will work. YOu could also see if you can get a 5"-6" piece of copper tube about 2.5" and put it around the transformer. Maybe a piece of Steel tube..
Id try twisting the wires But also connect one amp at a time see if it still hums.. Try moving the stuff around in the box when amp is on with no signal..
Have you tried to short the positive pin of the input jack to ground ? does the hum stop ?
J'
jleaman
THIS is a totally rough drawing.. sorry gimp is not that good with me :)
J'
ianpengelly
Hey Sansbury, I posted this link in your other thread, it might be relevant to your problem:
http://www.diyaudio.com/forums/show...&threadid=95451
Ian
sansbury
Ian- Thanks for the link. I read through, and saw lots of interesting stuff. What did you actually end up doing? I saw four things:
1) Two transformers
2) Peter Daniel's interconnected rectifiers approach (if I'm interpreting his approach properly)
3) Disconnecting network on safety earth
4) All of the above
Truth be told, it wouldn't kill me to just use one rectifier board for now, and build a "true monoblocks" approach later with two toroids when I feel like it, if that will give good results.
Mayday
I immediately went ahead and ordered two 225VA 2x24V~ transformers:D
It might get rid of the humming, though it's not disturbing when listening to musik, AND it'll free up my 500VA 2x24V~ transformer.
That's a candidate to be fitted with my BPA300....
ianpengelly
I am currently running a single rectifier board and I have the second transformer waiting to be installed. I would have done it by now, but it means altering the layout of the inside of the amp case and some rewiring.
I haven't done the disconnecting network yet, but i need to as the pops are driving me nuts! :bawling:
Mayday
Can't be lazy when it comes to DIY;)
DeanP
How will you wire this configuration(two trannies, two rect supplies and four ampboards) as that it what I want to do?
How does a person make a "disconnecting network "? and also apply this to the above?
sansbury
There comes a time when a man must make the fateful choice- to strip, or not to strip, that is the question. So I stripped things down and have decided to try reconfiguring the amp in a stereo mode first, and then decide where to go from there.
Here's roughly what I'm thinking. I realize there are potentially better ways to lay this out but I think that's going to wait for Rev 3. After all, if I do this one too well, then what will I have to build next?
ianpengelly
Nope, 2 transformers, 2 rectifier boards and 2 amp boards... true mono all the way.
There is some information on the thread I posted about disconnecting networks, which basically make connecting the amp ground to the safety earth a bit less problematic.
ianpengelly
quote:
Tis true, but I have had lots of other things to do. I'll get onto asap though now you have publicly embarrassed me!! :D
Mayday
Then my work here is done:D :devilr:
sansbury
FYI, I rebuilt last night with both amp boards connecting to one PSU board, moving the rectifier and amps farther away from the toroid (2-3"), and twisting the signal in/out and toroid->rectifier connections. I have not yet done a disconnecting network or the other more complex steps suggested above.
There was close to no hum or buzz, but a little bit could be discerned with your ear very close to the speakers. The rectifier-> amp connections are intentionally sloppy as I intend to reconnect in dual-mono when I get a larger chassis to work with.
I am using One Pi studio speakers, which have 94dB sensitivity, so maybe they're just very good at exposing things. With music, it all sounds great. I was playing MP3s and CDs off my laptop with iTunes. The amp has no volume control built into it and I plan on building a source selector/buffer/preamp to pair with it. Speaker cables are Dayton 13Ga from Parts Express on cheapo Radio Shack posts.
One thing I noticed is that one of my amp boards gets a bit warmer than the other one when the amp is not running or at very low volumes, and the offset (~95Mv) on this channel is higher than the other (~65Mv). At normal volume the temps equalize and neither are hot, just noticeably above ambient. I have not taken it up past 30% because I live in a smaller city apartment and I think it would crack the plaster in the walls.
Overall, so far, so good. Including tools and other things (I was starting near zero so I had to buy everything) I have a little over $500 in, and could probably build the next one for $300-ish. I am very happy with both the BrianGT kit and One Pi speakers and would recommend it without reservation to someone upgrading from consumer equipment.
owen
Thats more like it :D
Owen
Mayday
Today I put in two trafos; 225VA 2x24V~
I also put in a new heatsink and mounted a small fan in case it'll ever be needed, but I doubt it, new sinks are that much better.
The amp is now so quiet that I thought I had broken it when plugged it in, couldn't hear humming even with your ear against the speaker.
Page generated in 0.07388710975647 seconds with 17 queries,
spending 0.01309824 doing MySQL queries and 0.06078887 doing PHP things.
