diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
BUF-634 dc offset trim - Click HERE for Original Thread
hags
I'm looking for a dc offset trim circuit for the BUF-634 .
I have worked up a simple unity gain line buffer with it but the dc offset on the input/output is horrible.
I would like to stay away from any capacitor coupling.
Any suggestions would be much appreciated.
hags
Is there no way to null the dc offset on monolithic devices?
analog_sa
There are probably several ways. Assuming the offset is stable you may consider applying a similar dc voltage of opposite polarity at the input. Or use an inverting dc servo.
I personally think that the 634 sounds worse than most caps anyway.
Page generated in 0.023657083511353 seconds with 16 queries,
spending 0.01227021 doing MySQL queries and 0.01138687 doing PHP things.
