diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Closed enclosure help. - Click HERE for Original Thread
timcatn
Hi.
Im getting a JBL W12GTI mk2, and i wonder if anyone have tried to use this as a basswoofer in a home setup?
Best regards Tim
timcatn
BTW: thinking about using up to about 200Hz. is this possible ?
TwisterZ
Hello Tim,
Are you getting 1 or 2 of these woofers? In a mono sub setup you don't want to go higher the about 40-50Hz. Above that you start hearing where the sound is coming from and you will lose your stereo image.
Is this for home or car?
This woofer has a lot of displacement (4.23Liters) so it should make a very nice deep sub. The manual says that it can be used in an IB as long as you limit the power. This is always the case in that without an enclosure the woofer doesn't need as much power to fight the box pressure.
Looks like you are on your way to some great bass:smash: :smash: :smash:
timcatn
Thanks for replying. im getting 1 now, migt get another later. Gonna use a PA amp with built in DSP to drive it som i can experiment with different cutoff frequenzy. As stated this is for home use.
Tim
Page generated in 0.022705078125 seconds with 16 queries,
spending 0.00758719 doing MySQL queries and 0.01511788 doing PHP things.
Please support our sponsor.
