| BrianGT |
I had another batch of mini Aleph amplifier boards made, and power supply boards to go along with them. They are the same as the last batch and details on the boards can be found here:
http://diyamps.com/aleph/
This time, the boards have a black solder mask, white silkscreen, and gold plating.
As with last time, the amplifier pcb set is scored and easily breaks into 6 individual pcbs: 2 main amp boards, and 4 output device boards. The main board will work in the mini-A configuration without any output boards, or in the Aleph30 configuration with the use of the output boards.
I will put the boards up for ordering tonight/tomorrow morning on my website.
Pricing:
Amplfier pcb set: $9
Power supply board: $9
Shipping will be via USPS Priority/Global Priority, and will be $6 for US, and $11 for International orders.
Pictures
Brian |
| Jaac TheMaster |
Looks very nice !
If you see this, than why not order a set ?? let me think, do i need those board ?? no ! but they're very nice |
| jleaman |
Very Nice Brian
I think ill have to order a set to just have a set, I'll then have the red blue and red-smd now black/gold :)
To bad you don't use the ones we built when i was there. |
| batee |
The PS boards are beautiful! I'm considering a bunch of these for other projects I have going.
Any rough guesses at the current capacity of the PS boards?
Also: I checked the website and couldn't find a PS schematic. I'm having trouble visualizing how one bridge is fed by two two-wire AC inputs? I can see either a single three-wire, but not two two-wire inputs.
Thanks!
Bryan A. Thompson
bryan@batee.com |
| jleaman |
| quote: | Originally posted by batee
Thanks!
Bryan A. Thompson
bryan@batee.com |
The 2 in the middle can be shorted if you have a 3 wire transformer.. I used a 3 wire and a 4 wire.. With the 4 wire transformers you can twist the 2 together and make it a 4.. Want me to post a picture of the bottom of the board ?
| batee |
The bottom view explains what's happening with the AC inputs. It appears that they're already shorted via the connecting trace. That was the part that I was missing.
The rail traces look quite wide, so they aren't a concern to me. Do you think the traces between the AC input pads and the diodes will support 10A? 15A? I suppose that if there is space for six 3W resistors, and I use the leftover .47Ohm Panasonics sitting on my shelf, they would support 15A. I don't have a part number in mind, but think I've seen some fast diodes in a TO220 package that support 15A.
Thanks!
Bryan |
| jleaman |
| 15A what are you building ? thats a-lot of current. |
| batee |
| quote: | Originally posted by jleaman
An arc welder.
:bs:
Bryan |
| mpmarino |
Naw, a 500VA 20+20 trafo can push over 12A. I don't think 15A is too much to ask, and if you doubt the traces, you could always jumper over them too. I bet you'd be fine tho...
Man, if I didn't already have enough alephs I'd jump on this. They look great and the price is right:) |
| pchw |
| Waiting for the Currently out of stock text to change :D |
| batee |
Does anyone that's built one have any idea what caps they're intended for? Or what the size and lead spacing is?
Bryan |
| jleaman |
| I think it takes the panasonic Snap in cap's I can get briangt to post the parts express number. |
| twitchie |
You can order the boards from www.chipamp.com not the aleph diyamp link posted above.
I have a Plitron 625VA 18+18V transformer pushing over 17A through one of the blue boards in an A30, and it hasn't melted a hole through the chassis yet, so I think 15A is safe (disclaimer: your mileage may vary) :angel: |
| batee |
Thanks, that's what I wanted to know!
Any idea which Panasonics fit it? I'll probably use the largest 35-50WVDC caps that'll fit (whether I need to or not). I'm just trying to figure out what cost for those is going to be.
Bryan |
| Jaac TheMaster |
On braingt his site he posted a excel sheet for the parts with partnr of digikey
I've done some searching on the panasonic site an came up with the following:
Digi-Key_________type________panasonic part#______can diameter
P6887-ND_____10,000uf 25v____ECO-S1EP103DA_____30mm
P6914-ND_____10,000uf 35v____ECO-S1VP103EA_____35mm
P6922-ND_____22,000uf 35v____ECO-S1VP223EA_____35mm
P6940-ND_____10,000uf 50v____ECO-S1HP103EA_____35mm
P6946-ND_____22,000uf 50v____ECO-S1HP223EA_____35mm
Al the panasonic caps that begin with ECO-s are 10mm pitch lead
source: panasonic site
look for "large can catalog" and "dimensions specifications" |
| BrianGT |
| quote: | Originally posted by pchw
Sorry for the confusion. I put them on the Chipamp.com order page:
http://www.chipamp.com/orders.shtml
Everything seems to be fine for that order page. I will update the link on the Aleph page.
Brian |
| Jaac TheMaster |
| I'm updating my paypal account you wil hear of me soon ! |
| twitchie |
The panasonic caps listed (and shown in the photos) are TSHA caps - the digikey numbers for those are in the excel spreadsheet
I used 22000uF 35V caps P6671-ND I think - I have the 15000uF caps as well P6668-ND.
There were some posts buried in some threads recommending the TSHA caps. |
| MashBill |
Thanks Brian! I've been waiting on these for a long time! Order sent.
Thanks again!
Bill |
| Jaac TheMaster |
| order sent, any idea how long it takes to arrive ? |
| potepuh |
Order sent, any idea how long it takes to arrive in Europe?
Thaks Brian |
| BrianGT |
Shipping to Europe generally takes 4-7 days, but might take up to 10 days.
Brian |
| pchw |
| Received the boards today, they are gorgeous, thank you, Brian. |
| MashBill |
+1 on that! They are beautiful! Thanks Brian!
Bill |
| BrianGT |
Yeah, I am amazed myself at how good the black ones look. I have had a set on my desk since the boards arrived, and I am still amazed at how good they look. I had them next to a set of the previous blue boards, and set of the previous red boards, and the black is clearly my favorite. I think that the gold helps my decision also :)
I have almost all of the pcb orders shipped out, and will ship the remaining ones out by the end of the week.
Wishing you all good easter weekend, and best of luck on your projects!
Brian |
| jleaman |
| quote: | Originally posted by BrianGT
Brian |
Thanks for posting that information for the members Brian, yuo have a good easter weekend too.
J' |
| TomWatson |
| I placed my order for a few powersupply boards last night and still no confirmation from brian my money was recieved, ah well shouldnt of procrastinated so much this close to the weekend:xeye: Have a good one!;) |
| BrianGT |
| quote: | Originally posted by TomWatson
I received your order, and will work on putting it together tonight with the rest of the remaining orders.
After putting aside the boards to fill all the current orders, I am out of stock of the Amplifier PSU boards for future orders. I will place another order for them on Monday. I didn't expect them to go this fast. I still have plenty of the mini Aleph pcb sets left.
Brian |
| batee |
I placed my order on 3/30/07 (last Friday). He notified me on 4/2 (Monday) that he had shipped, and they arrived today (4/5/07). They're freaking beautiful!
Does someone have a source of black anodized heatsinks for the FREDs? The last ones I got from Digikey were Gold.
Thanks again!
Bryan A. Thompson
bryan@batee.com |
| jleaman |
Thanks again!
Bryan A. Thompson
bryan@batee.com |
I know for a fact that bran has boxes of them :) i was there i sorted the whole box of them. Maybe JUST maybe he can sell you a few :D |
| twitchie |
the 0.79 cent heatsinks will NOT fit, but the #7022 (0.20 ea) will - although you may want to use 2 per diode back-to-back |
| Jaac TheMaster |
Brian |
What do you expect with NP and all his new amps ! did you received my order ?
gr Jaac |
| BrianGT |
| quote: | Originally posted by Jaac TheMaster
gr Jaac |
haha, I guess you are right. I have your order, and should be able to mail it out today.
Brian |
| jaybombalous |
How long till you think the new PSU pcb's will be in if ordered on monday?
I think I will be purchasing my aleph set sometime today. :) |
| Jaac TheMaster |
The boards arrived today !!! They look very very good in black PIB (Pcb's In Black). Now some F4 board's some heat sinking and a toroid
Thanks brain good job !! |
| TomWatson |
| Horray got my ps boards intoday, damn theyre nice:cool: |
| BrianGT |
The next batch of PSU boards should by the end of next week. We will see how long they last this time :)
Brian |
| jleaman |
Brian |
Well, they are a really good design and work well in lots of project's no wonder they sell so fast :) Good job :) |
| jaybombalous |
Brian |
I need at least two... Better mark me down for three!!! Received the amp PCB's, they look good.
I just got one question. What is a good source for the IRF9610's? Digikey.com wants 1.01/per at 400 for a minimum order...
nevermind, I answered my own question... |
| sqlkev |
what exactly would i need for 4 monoblocks of the aleph 30?
(i'm hoping there would be some left for me to order :( ) |
| sbrtoy |
Brian,
Any chance you have a wiring diagram or schematic for the A-30? I have a set of your older blue boards and don't have a reference for how to wire up the Mini A board to the power boards, don't want to fry anything!
Sam |
| wdavis009 |
| quote: | Originally posted by sbrtoy
Any chance you have a wiring diagram or schematic for the A-30? |
+1
It's no longer posted on Pass Labs site for some reason, and I can't find my old copy. :xeye:
BTW, the amp boards arrived today and I have to confess the black boards are really sharp. I think they are my favorite of all the different colors. I wasn't planning on ordering more PS boards as I have a few of the blue boards, but I have changed my mind. You can put me down for 4 sets of PS boards. |
| shallbehealed |
| ETA on powersupply boards? |
| jaybombalous |
I do believe he said by the end of this week they should be in...
I am very interested in two myself, I sure hope he made enough this time to last for a while. |
| space |
I recived 2 pcs powersupply boards the 10. of april...but i didn't order any! (Ordered 7 pcs N.I. LM3886 pcbs)
The envelope containing the pcb's is named T. Cameron. Anyone missing these? I've been trying to reach Chipamp for two weeks but havn't got a responce.
Karl C. Kristiansen |
| BrianGT |
| quote: | Originally posted by space
Karl,
It looks like I missed your first mail, but I received your last one. I am shipping out your current order to you now, and the correct order to T. Cameron. I am sorry for the mix up. You can keep those boards.
As for the new batch of PSU boards, they shipped on Tuesday, and should arrive today. I hope that they will last longer this time, but I can always order more of them if these don't.
Brian |
| Pathmark |
Brian,
Do we have to wait until website is updated or should we be ordering through this post?
Thanks,
Pathmark |
| space |
Karl,
Brian |
Great!
space |
| ssmith |
Payment made for 2 sets (planning on building two stereo amps for biamping project).
Have also ordered Kristijan's (much more expensive) Mini-A PCBs -- annoying as placed the order just before this new run was announced. Will be interesting to compare... |
| BrianGT |
| quote: | Originally posted by Pathmark
Brian,
Thanks,
Pathmark |
All ordering is done through the website:
http://www.chipamp.com/orders.shtml |
| shallbehealed |
Brian,
There should be an email from Minneapolis re: shipping address in your inbox. Please let me know once this has been worked out.
Doug |
| EvilYoda |
There are a lot of resistors to find prices on, does anybody have a rough figure for the total parts listed on the Excel files? The PS looks like there are $63 worth of parts...does this sound right? (I chose the dual mono caps)
A total figure would be nice...I don't think that the aleph and output boards will cost that much. |
| jleaman |
| quote: | Originally posted by EvilYoda
Want some free through hole parts ? you pay for shipping i can give you some stuff.
J' |
| shallbehealed |
J' |
I'd take that deal in a heartbeat. |
| EvilYoda |
| quote: | Originally posted by shallbehealed
I feel the same way, so I just emailed him :D |
| jleaman |
What goes around comes around i guess. :P |
| shallbehealed |
| Just got my boards today. I almost feel bad putting solder on them. So purdy. |
| Looneytunes |
Brian,
I received my Aleph & PSU boards last weekend. Very nice! Almost too pretty to solder... almost! :)
Looney |
| EvilYoda |
Got mine today! Wasn't expecting a package, so it was a pleasant surprise.
And yes, very pretty...can't wait to put them to work :) |
| imix500 |
| Got mine too last week. Super fast shipping there Brian. Beautiful boards!! |
| Tristanc1 |
Brian,
Just wondering if you received my order for 2 aleph pcbs, and 2 aleph power supplies?
Thanks!
Tristan |
| koenigmarkus |
Hello Brian,
like Tristanc1, I just wondering if you received my order for 1 aleph pcb, and 2 aleph power supplies? I ordered on June 20th and still got no PCB or an reply from you. I've send you a few email's and still got no answer too...
Thanks!
Markus |
| Speedsmile |
| Same here, although I ordered a lm3886 kit last week, but no e-mail replies, anyone knows what he's up to :>, perhaps holiday or something? Last time he was online was only last Saturday, so it is a little strange that Tristanic didn't recieve any replies either.. |
| Tristanc1 |
Just to let everyone know I did receive my boards:) They were held up in customs....
Thanks Brian!
Tristan |
| BrianGT |
| quote: | Originally posted by Speedsmile
Sorry that I missed this thread earlier. The best way to reach me is through gmail through my chipamp at gmail address. If you still haven't received anything, drop me an e-mail.
Customs delays seem to occasionally happen when shipping to Italy and Canada.
I still have a handful of aleph boards left, and am not sure if I will place another order of these any time soon.
Brian |
| Speedsmile |
| I indeed still don't have a reply from you, but don't worry cause I got a tracking number from you yesterday, so I assume you're working hard to get my order shipped :D, my e-mail was mainly about the fact if you received my order correctly due to the stupid fact I closed the paypal window accidently after payment confirmation, and didn't know if you recieved the order correctly...:confused: :angel: |
| BrianGT |
Sorry about that. I just found your mail (had to dig through 3,500 spam messages). I had my old e-mail set in the control panel, which I had to stop using due to spam issues. I fixed this, and shouldn't have problems with this in the future.
Best of luck on your project!
Brian |
| Speedsmile |
Hi Brian, could you please check your mail again?, I dropped you a mail last friday. The USPS tracking number still says that they didn't get the actual package, not a big deal, but I'm starting to get a bit worried because I'm leaving the 5th of September to a 3 month internship in Norway, and I'm planning to take the completed amp with me..
That's 3 weeks from now, so time is slowly ticking away...so I would appreciate it if you could inform me when my order will be shipped.
Thanks,
Maarten |
| BrianGT |
Thanks,
Maarten |
Maarten,
The package shipped out at the same as when you received the tracking number. I am not sure why the website has not updated the information. The standard arrival time is typically 4-7 business via USPS. I would expect it to arrive by the end of the week.
Best of luck on your project,
Brian |
| Speedsmile |
| Hi, thanks, I was suspecting something like that...thank you very much for your products...I will sent you a picture of the completed amp to put on your site when I'm finished |
| Speedsmile |
| And guess what...I just recieved your package....thanks |
| BrianGT |
Great!
On a side note, I am out of Aleph boards now and you received one of the last sets.
All current orders for them were shipped out, and I might do order another small batch of boards sometime in the future if there is enough interest. I still have a handful of the PSU boards left.
Brian |
| koenigmarkus |
Hello Brian,
sorry to tell you, that I am a little bit disappointed because I ordered and payed your aleph-pcbs in June, but got none. I' ve sended you a few e-mails, but got no reply from you. What's up?
Markus |
| jleaman |
I am sorry to hear about this, i have contacted briangt on your behalf.
actually, i just called brian for you, can you please pm me.
Jase |
| koenigmarkus |
Hello Jase,
thank you for calling Brian.
I can't contact you via pm, because my account is under moderation. I did not enough posts. Please send me an e-mail and I will answer you. m.sagau at freenet.de
Markus |
| eaferrer |
Hi Brian,
I ordered two sets of lm3886 pcb and a pair of power supply, almost two weeks ago.
Can you please tell me how long it would take to be delivered here in riyadh ksa ?
Thanks,
Sonny Acance |
| BrianGT |
| quote: | Originally posted by koenigmarkus
Hello Brian,
Markus |
Markus,
I am sorry, I was gone for the weekend. I am looking into this now. The order was shipped out, but apparently did not arrive to you. I believe that I have additional boards in my parts bin that I can mail out to you, or I can offer you a refund.
Brian |
| BrianGT |
| quote: | Originally posted by eaferrer
Hi Brian,
Thanks,
Sonny Acance |
Hello Sonny,
Your order was received on the 15th, and shipped out the 17th. It generally takes 5-10 business days to get to most international locations. Occasionally it can take an extra week or so due to customs delays. I have not shipped many packages to Saudia Arabia, so I don't recall any specific delivery times. If you don't receive it in a week, drop me an e-mail, and I will check further into it.
Brian |
| koenigmarkus |
Brian take care of my problem.
Thank you Jase and Brian.
Markus |
| jleaman |
Markus |
Very happy to know, and extremely happy i was able to help.
Jase |
| Daveze |
How would one register interest in a future run of the Aleph amp boards?
Josh D |
| jleaman |
| quote: | Originally posted by Daveze
Josh D |
So you are interested in more boards ? What ones smd or through hole ? |
| rastafazz |
Josh D |
I'm interested as well (through hole boards) ;-)
Steph |
| marsupialx |
| I, too, am interested in a set of through hole boards. Thanks! - marsupialx |
| Daveze |
I'm fairly happy to go with the majority but through-hole would be my preference.
Josh D |
| eaferrer |
Hello Sonny,
Brian |
Hi Brian,
Still no sign of PCB . . . huhuhu
Sonny |
| zenesh |
Hi Brian,
No more mini Aleph boards yeah? Well just trying my luck. Hopefully there will be enough interest for another run of boards.
Cheers |
| koenigmarkus |
Hi Brian,
I'am also get no PCB's . When do you shipped them out?
And didn' you get my emails? I am asking, because I've got no reply from you...
Markus |
| jleaman |
Hi Brian,
Markus |
I'm starting to think he should just refund you, you must live in a area that has bad postal service.
Jase |
| koenigmarkus |
Jase,
I 've sended a few mails after you call him and made the offer, that, after the pcbs arrived, I pay the half price again, because I thing its not his or my fault, so both have only the half disprofit...
But I got no answer until today. I don't know, if he find some boards in his parts-bin and shipped them out and if, to witch address. That's why I ask again. Because he do not reply, if I send emails to him, I ask here too...
Markus
Btw:All letters from Bowling Green/ Kentucky/USA and Gridley/ California/ USA found the right path in my letterbox. The postal service can' t be so bad... |
| eaferrer |
| I am sending him emails too, but Brian seems to be somewhere else. I'll wait for one more week and thats it! I want a refund . |
| jleaman |
You could do that, however you must understand Brian has a family and a life. I'm going to recommend to him that he stops selling boards, some one else can take all there spare time and do it.
You must also remember you live in foreign country's where the postal services are slower, AND customs is picky with packages.it
It took me 6 hours to fly to his house, however it takes 5 weeks to have something from him mailed to me. Patience people. If Brian said he has mailed something to you , you will get it, trust me! |
| jaybombalous |
as much as I have sent and received packages to and from foreign countries world wide over the past 2 years, I have never seen a package take 5 weeks to arrive anywhere.
Thats just really sad, 5 weeks. :( I'd ask for a refund too.
Hopefully the boards will arrive, I know how frustrating it can be waiting while your money is tied up in someone else hands. |
| koenigmarkus |
ok patience, no problem.
I don't know, how mutch emails Brian get at the day, but will it take so mutch time, to send only a short answer like : I'am busy, please wait, until I have the time to ship the boards out...?
I have no problem to wait, but I don't like to know nothing...
Markus |
| jleaman |
oh, i guess you guys didn't think or take into consideration that brian paid out of his pocket to purchase all these boards that collect dust till some one wants one, BRIAN has spent numerous hours and hugs amounts of money doing this ALL from which came from his own pocket. PLEASE understand Brian does have a life now, I totally understand why he was talking about getting out of this, it all comes clear now.
I will call Brian in a bit and talk to him and inform him that his decision to stop selling should also be considered too.
Jase
EDIT: Just called his cell, he is out of town. |
| es44 |
Big surprice, Brian even has a job too to attend to ;)
No worries people, if Brian says he has send packages, then it's true. As others said, there could be lot of troubles on the way from him to you. Mail, customs etc.
Have patience, and remember, that He's done a great job with literally no profit just to make us all happy. And the prices are low too.
Greetings to all of you.
ps. Brians boards are well worth waiting for. |
| BrianGT |
I am sorry, was out of the town with the wife for the weekend.
I do not know what the issues with these two orders are. They were shipped out, and show that the US post office received them, but they were never delivered, or returned.
I will refund these two orders. |
| eaferrer |
Yeah! So you can start giving me a refund now.....
Sonny, |
