diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
Regulated or NonRegulated PSU. - Click HERE for Original Thread
samsagaz
Hey guys, can someone tellme ghe benefits of the use of an regulated vs an non-regulated PSU for an AMplifier?
star882
regulated - higher quality, better performance, sometimes better efficiency
unregulated - simple, cheap, more common
samsagaz
ok! so looks like i will go with regulated..... :)
yusuf
quote:
http://myweb.tiscali.co.uk/nuukspot...gainclone6.html
samsagaz
quote:
Thanks too much, very good info, one question about the The Snubberized version, is possible to use just one transformer instead 2? if use just 1, will be bad?
yusuf
I assume single secondary instead of two. yes you can but design with be different. Two secondaries has only one advantage that you can use +ve regulator for -ve output.
AndrewT
major disadvantages of regulated supplies include the following:-
extra cost of the regulator.
extra cost of the higher voltage transformer.
extra energy used to operate.
extra heat to be dissipated.
extra space to accomodate the reg and heatsink
design expertise required to ensure the regulated PSU operates correctly with the amplifer. (it is more complicated to design a good, well-behaved regulated supply than to design a discrete amplifier).
Advantages of unregulated PSU:-
cheap.
simple.
easy to assemble.
design expertise easy to find/acquire.
adequate performance that near enough matches and sometimes betters regulated.
A biased view, stick with unregulated and you won't regret it.
ps, don't bother with dual rectifiers. A single rectifier with dual capacitors for EACH amplifier. Share the transformer between channels but dedicate a PSU to every poweramp.
odnaizutra
regulated not very easy in feedback.
Just use smps like crown ,unregulated and a lot of capacitance at output.The secret is the way to wind power trafo.
Just read Eva and N-channel advices about this.
yusuf
IMO, regulated power supply should give you most out of your chipamp provided your regulated output in optimum for your input and output signal.
Any larger then optimum supply voltage on chipamp will reduce the driving capabilities of chipamp. It will also increase heat for same output. So if you have regulators with heat sink, that heat should be distributed between chipamp and regulator (excess voltage will be now across regulator and not on chip amp).
Again, that depends on voltage situation in your part of the world. Place I live has extremeley large variation and I would not go without regulated supply. However, if this is not the case with you, even unregulated supply may do for low variation. And offcourse, unregulated supply has its own benefits as Andrew mentioned above.
Yusuf
CBS240
Hi
IMHO, if the amp is descrete and has a follower output stage, two power supplies can be used. One is unregulated, for the follower output, the other is bit higher voltage lower current to run the regulators and amp less the large follower collector/drain current. Smaller regulators are cheap and easier to implement, yet still able get the advantage of voltage regulation for the power amp. This may not be an option for chip amps though.:dodgy: :smash:
Tweeker
I like critically damped choke input supplies, you dont see them in SS stuff much though. A large, snubbed, low DCR choke followed by enough capacitance to damp it.
Some IC regulators have rather variable ZO at high frequency.
Page generated in 0.032429933547974 seconds with 17 queries,
spending 0.00948405 doing MySQL queries and 0.02294588 doing PHP things.
Please support our sponsor.
