| yusuf |
Attached is schematic and PCB layout of LM338 based Regulated Snubberized PSU.
I am looking forward for your comments before I give it for fabrication.
Yusuf |
| yusuf |
Attached is schematic.
Yusuf |
| head_spaz |
I like it.
But... if you plan to pull a few amps from those lm338's. I would recommend larger heatsinks. |
| redrabbit |
Snubberized?
=RR= |
| jleaman |
What is the rail voltage ? How much current can be draw at a constant ?
Are you going to get some boards made ? |
| BWRX |
| quote: | Originally posted by jleaman
What is the rail voltage? |
Whatever you set it to be within the limits of the part.
How much current can be draw at a constant? |
That depends on which part you use. The LM338 is rated for 5A continuous with adequate heatsinking. |
| m-tech |
| quote: | | The LM338 is rated for 5A continuous with adequate heatsinking. |
Yes, but input-output voltage differential must be 10 volts, or lower.
Maximum recomended dissipation is 50W. |
| yusuf |
| quote: | Originally posted by redrabbit
Snubberized?
| Yes, it has provision for snubber RC component as suggested by carlos.
| Output voltage and current depends on component you use. Please check datasheet of LM338 or LT1083.
Yes, I am going to make two 70 micron boards for myself. If someone is interested, I can order for them too. You only pay the charges at actual.
Attached is updated layout with provision of LT1083.
Please provide feedback and any inputs for improving it.
Yusuf
