diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
STAIS3 Power Amplifier - Click HERE for Original Thread
Rolexmonger
Is there a safe and reliable way to get this amp to run hot, like the 400a, its predecessor? If so, how much is involved? I.E. is it more a matter of parts or of tweaking and re-biasing? Thanks for any help.
steenoe
Sorry, but this might be a stupid question: Why on earth do you want your Stasis 3 to run hot?
Me sure dont get the point:)
Steen:)
Nelson Pass
It's simply a matter of very carefully adjsting the bias pots
to bring the sink temperature up. The maximum recommended
temp is 55 deg C. on the sinks after an hour warmup.
:cool:
Rolexmonger
This is a reply to the guy from Denmark and a question to Nelson Pass. I want it to run hot because the Threshold equipment sounds better when it runs hot. The question to Mr. Pass is, since you already advised how hot the Stasis can be adjusted to run, I am assuming that this is a safe modification?
Page generated in 0.019284963607788 seconds with 16 queries,
spending 0.00775075 doing MySQL queries and 0.01153421 doing PHP things.
