| computer subwoofer amp - Click HERE for Original Thread |
| blue934 |
hi guys, a couple of years ago i came across a small sub plate amp designed for computers. it used the line in from the computer and had high level outs w/volume for the satellites. now that i want to build a samll sub i can't find the amp anywhere. any ideas?
david |
| MJL21193 |
| Did you look under the bed?:rolleyes: |
| blue934 |
thanks guys, MJL21193 - you are the man. it was under the bed in the spare room! i did look at those units raoul, but they do not allow satellites to be powered out if the line in jack is used. as i am coming from the computer, 1/8 line level is all i have. i found the one i was looking for at www.solen.ca. the KG-3100 is a 50 watt sub amp w/25w x 2 output w/volume control. perfect for computer systems, ipods, or mp3 players.
thanks again
david |
| Raoul |
Yeah, I realized that those amps might not be what you were looking for after I posted. Kudos to MJL21193 for his practical, common sense approach
