diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
tda2005 Spice Model or other 12v op - Click HERE for Original Thread
matrix99
my english is not so good but i will try
I try to find model of this tda with no results
only i foud tda2005 datasheet www.electronic-kits-and-projects.co...ets/tda2005.pdf
i need to simulate this i also try make model with tutorial http://zone.ni.com/devzone/cda/tut/p/id/3173 no reeults :(
on google i only find this (file is in attachment) but ther is no output becouse tda2005 on schema not have data parametar
can anyone help me???
also i can use som other chip with 12v power
tnx
consort_ee_um
Have a look at this:
http://www.ecircuitcenter.com/OpMod...20V%20Limit.htm
It showas how to limit the output voltage of an op-amp which is essetially what the 2005 is
Page generated in 0.021361112594604 seconds with 17 queries,
spending 0.01035094 doing MySQL queries and 0.01101017 doing PHP things.
Please support our sponsor.
