diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
6X4 Tube rectifier. - Click HERE for Original Thread
SINGLEENDED
6X4 Tube rectifier: :D Need some answer to the above.
What is the life span for the tube, if I were to use it daily for 8 hours.:confused:
sawreyrw
I think it should last thousands of hours, if you operate it within its ratings. It is a relatively low current tube.
Eli Duttman
Well made vacuum rectifiers have long service lives. 10+ years is not an unrealistic expectation. Who made your 6X4?
sorenj07
also, what does the current load, idle and max, look like on your (pre)amp?
ulibub
Hi!
I use the 6X4 as a rectifier in a hybrid bridge (with two BY 127 Si-diodes) in the power supply of my preamp, who takes about 50 mA at 300V. Rectifier input voltage is 450 V AC. From the tube's cathode, there goes a NTC resistor (ca. 300 Ohm cold, a few ohms hot, to reduce startup current) to a 50 uf electrolytic, a 5 H choke, another 50 uf cap, and then into the first regulator tube, a PL 84. Voltage reference is a TAA 550 temperature-compensated precision zener voltage source (33 V).
I built this amp in the late 80's, and at the moment where I am writing this posting, it has run 22,869 hours.... (I have a counter in the PSU....;) ), always with the same tubes.... This also applies to the PL 84 / PL 95 / PCF 802 in the 2-stage regulated power supply....
So far I don't see any signs of weakening of the tube(s)....
Don't know how much you'd charge the tube, but with the above data you easily could expect about 8 years of 8 h daily service.... (23,000 : 8 : 365)
Uli
SINGLEENDED
6X4 Made by GE 60' NOS.
I run it this way. 220 CT . to 6X4 . First oil caps. at 15uf non polar.next comes the choke @ 8H 100mA , another caps @ 68uf. next another choke 8H 100 mA last caps 68uf. So its CLCLC.:) :)
ulibub
how much current do you draw out of the power supply? My 6X4 is a NOS made by Tungsram.
Geek
6X4 is a good tough little tube. Used it for hundreds of hours in a headphone amp feeding into a cap twice the recommended size. Zero failures :)
SINGLEENDED
The pre amp. consume 250vdc @ 100ma.:angel:
Eli Duttman
IMO, that's too much for a 6X4. 70 mA. is "normal". Look at the data sheet. While I wouldn't worry if the draw is 75 mA., a switch to the 6CA4/EZ81 is indicated, if 100 mA. of B+ are really needed.
ulibub
indeed, like Eli said, this even exceeds the ratings of the next bigger tube in this row, the EZ 80. (rated for 90 mA max.). And I prefer running the tubes not at their limits, especially not rectifier tubes. Forward drop increases quite much when running them close to their limits. So indeed take a EZ 81, or, if you can provide for a separate 5 V heater supply, the GZ 34 (5 V, 1.9 A heater (connected to cathode), EZ 81 is 6.3 V, 1 A, heater isolated from cathode) and has at 100mA only a few volts forward drop. EZ 81 has 15 V there, GZ 34 only 8 V.
Uli
SINGLEENDED
quote:
Uli
I have a couple of EZ81 brand ultron ,3pcs of GZ 34 rca , 6X4 tungsol , 6X4 raytheon , 6X4 ge, and trying to get my hands on Haltron if you can help.
Why 6X4 ge and at their peak limits. 1, it is very quiet . 2, it is not pushy compare to others, 3, open soundstage. .
Btw the preamp is feed from oil bath trans supply.
ulibub
I can recommend the tubes of actual production from www.jj-electronic.sk. They habe both EZ 81 and GZ 34 in production. But brand doesn't really matter with rectifier tubes as long as they are quality products.
But for what do you need an oilbath transformer for your preamp???? Is it fed directly from a high-voltage line????
SINGLEENDED
Brand does not make the sound.
Different manufacturer make their tube differently.
I like GE & Haltron they sound open and warm.
JJ is not so good I have a few pieces.small sig.
Yes it is feed directly from the high voltage line.
And yes it really make the whole set up sound different. Very quiet i should say.
Page generated in 0.038274049758911 seconds with 17 queries,
spending 0.00901914 doing MySQL queries and 0.02925491 doing PHP things.
Please support our sponsor.
