diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
tube mic design (opinions ?) + high value resistors - Click HERE for Original Thread
garyk
Last year I built the "Royer" mic (mod) using an ADK 51 mic and the 5840 sub-min tube. Sounds very good, used a Cinemag output transformer.
I have acquired a Peluso double sided C12 type capsule to make another mic, but wondered which circuit/schematic to try this time.
Most of the diagrams for set ups like the elaM250 or the C12 use very high value resistors (eg 60m- 100m - 150m).
So: two questions:
a) any suggestions for the best schematic, tube, tranny, etc, for this capsule?
Could be anything from the 5840 to EF86, 12AY7 ..etc...anyone tried the nuvistors?
Might be good to try to emulate the C12 or the elaM250?
b) where to get these high value resistors (not available here in Australia?)
Gary
cliff
Farnell should stock them, or you can use a string of 10M 5% film resistors.
garyk
yup.. but @ 150m thats a LOT of resistor strings to chuck into a little mic casing ...
cliff
Well, theyare available eg
http://rswww.com/cgi-bin/bv/rswww/s...ction.do?Nr=AND(avl%3auk,searchDiscon_uk%3aN)&Ntx=mode%20matchpartial&N=4294730713&in_dim_search=1&name=SiteStandard&forwardingPage=line&R=2477799&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0933770793.1174153587@@@@&BV_EngineID=ccccaddkgiedmlhcefeceeldgondhgl.0&cacheID=ukie
but I don't know how easy down under.
Page generated in 0.021028995513916 seconds with 17 queries,
spending 0.00850272 doing MySQL queries and 0.01252627 doing PHP things.
