diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
power supply choke with a connection for AC ground? - Click HERE for Original Thread
jarthel
I bought a choke and it has a 3rd wire for the AC ground. this wire is not connected to any of the other 2 wires.
should I connect this to ground? does it have any positive effect?
thank you.
leadbelly
quote:
Yes, just as you would/should chassis ground any power transformer.
Potential life extension :)
jarthel
thank you
senderj
If my choke does not have one, is it possible to make one myself? From the metal surface of the choke to AC ground or psu ground?
leadbelly
quote:
Yes, the metal of the choke should be grounded. If mounting to a metal plate, I don't bother with a separate wire, I just make sure that there is metal-metal contact (not painted-metal-to-metal contact). If there is some reason why that can't be done, I just make a bonding wire with a washer style connector on the end so that the mounting screws will hold the wire to the metal.
Page generated in 0.020904064178467 seconds with 17 queries,
spending 0.00764465 doing MySQL queries and 0.01325941 doing PHP things.
