diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
help making sub filter pcb! - Click HERE for Original Thread
hernanstafe
Well I was using protel to try and make a pcb for this circuit
http://www.electronicafacil.net/cir.../esquema28.html
but for some reason it keeps giving me errors when i load the netlist into the pcb; i've tried to use protel lots of time (Protel 99SE) and it keeps giving me headaches.
Can anyone do me the favor to generate a pcb for that circuit? it has to be single sided, i can give you the sch file if you want, i just need someone to generate the pcb for me cause i keep trying and failing!!
MJL21193
I have EW Multisim/Ultiboard. I can give it a shot. One layer or two? Simple enough for one layer. The opamps will be DIP? Two dual or single quad?
djQUAN
I can see that the page shows the schematic of ESP's P48 subwoofer controller and there is no link to ESP.
http://sound.westhost.com/project48.htm
I smell a copyright violation here............
you can buy ready made boards from Rod from the above link.
MJL21193
You are absolutely right djQUAN. Count me out. Have too much respect for Rod's efforts to do that.
hernanstafe
Hey guys! sorry about that! that page is NOT MINE! i just found it, didn't figure that out. I'm really sorry for that.
Dr.EM
Wouldn't think there would be any issue with constructing this on stripboard so long as you can afford the potential extra space it would take up?
Page generated in 0.026875019073486 seconds with 17 queries,
spending 0.00937366 doing MySQL queries and 0.01750135 doing PHP things.
Please support our sponsor.
