diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
High Quality Sub Drivers - Click HERE for Original Thread
matt09
I realise this may be a question asked frequently, however strangely I was not able to find anything on the Forums.
At the moment I have my eyes set on an Ascendant Audio Avalanche 15 for a sonotube idea (see other thread) which are said to be some of the best drivers for the price avalable. However, I may not be able to get hold of one as they are becoming increasingly rare. What other similar quality drivers (or newer better ?) substitutes are avalable in the UK for a max price of ~ £130 - no parts express:(
The Avalanche 15's have the following T&S
Fs 15.7 Hz
Qms 3.5
Qes .334
Qts .305
Vas 300.6 L
Re 3.2 ohms
Znom* 4 ohms
Xmax 27 mm
Sd 749 cm2
Mms 269 g
Vd 4.04 L
Pnom 800 watts
Le 2.4 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.875"
Weight 37 pounds
Lastly, Don't suppose anyone knows somebody with a barely used Avalanche 15 ??
matt09
Anyone ?
richie00boy
Made in Scotland, unrivalled quality and the guy is a legend, if a bit eccentric (in a nice way) www.shadowworks.co.uk only thing is they are 12 inch not 15.
tinitus
Are these MAX Caliber any good - theres a 15"
http://www.pa-direct.co.uk/drivers.htm
matt09
@ richie00boy: Thanks for the reply, however they appear to be a little out of my price range with the drivers costing around £600 each or more. Are there not any subs with the quality of the Avalanche's so cheaply?
I shall have a look at the PDF for Caliber driver.
SimontY
quote:
Hi Rich,
They look interesting, but I can only see one or two prices on their website, such as £1500 for a pair. Am I being thick here??
Simon
richie00boy
Yes you are both being thick :D
The £1500/pair is for a custom matched pair of the top model Goliath drive units.
The range of drive units starts within your budget, that's why I mentioned them.
SimontY
It costs £400!! Not cheap!!
Simon
SimontY
Hehe, where can we see the prices please?
richie00boy
Best to drop them an email, mention diyAudio and that I recommended them and they will look after you :)
SimontY
Now that sounds like a plan for our friend.
matt09
Looking at the T&S, generally the Fs seem quite high for sub bass driver at > 30hz but am I wrong?
I am wanting to achieve a response from around ~50 hz down to ~15 using a sonotube construction method which is why the avalanche seemed so suited with an Fs of 15.7 hz as well as the quality. I have struggled to even find another 15" driver with an Fs this low.
SimontY
quote:
I don't think you're wrong. I use a Tempest (15" similar to Avalanche in many ways I think) in a 270L ported box tuned to 20hz, which is probably not far off what you're looking at doing. With other drivers you can always go smaller and sealed and use a bass boost to bring the bottom up (Linkwitz Transform circuit). The downside there is lack of maximum output level.
I've never seen drivers like Tempest, Avalanche etc. for sale in this country, at least not cheaply. I had mine shipped over from the States and would never do it again! Import duty, shipping cots, faulty/rubbing driver, massive waits etc...
Simon
zuki
why not have www.ficaraudio.com build you what you want ?
i wish i knew what size box those jbl would do best in, as they are 50.00 each 4 15 is 200.00
:bigeyes:
matt09
Hmm kind of goes back to the original question of what are the best drivers avalable in the UK for around £130 similar to the avalanche with low FS.
I doubt they would built a sonotube design and and I would have to pay for shipping costs of materials.
zuki
I doubt they would built a sonotube design :confused:
he built the woofers for svs
ask him.
zuki
http://www.imagedynamicsstore.com/i...10d81f7fbc92640
it says free s/h
:D
he built these woofers too.
http://www.stevemeadedesigns.com/bo...?showtopic=4066
matt09
They do look nice, although having never heard them or know of the general oppinions from other people with them being more expensive sub's, I am understandably questionable. Mainly due to the Xmax of just over 10 mil, I'm not looking for SPL but i do wonder how well it would hit the 15hz lows i want to aim for with such a low displacement.
zuki
fi audio used to be resonant engineering.
steve meade is sponsored by fi
fi made the woofers for svs.
Page generated in 0.052962064743042 seconds with 17 queries,
spending 0.00999570 doing MySQL queries and 0.04296637 doing PHP things.
Please support our sponsor.
