| audiobahnkid592 |
| I just made this box to see the potential of my subwoofers. It could have been built ALOT better so dont nag on me because I already know but here it is. BTW I desinged and built the entire thing myself and the only thing I used for the lettering was a pic of the logo and a circle stensile. |
| audiobahnkid592 |
| before covering |
| mikee55 |
...it performs like?
I could make my Granny look pretty if I covered her, but she'd still be old. Do your speakers impress your sight or do your ears get a look in? You can't tell me you didn't give them a choon or two? Even with the wrong box dimensions, you can HEAR potential!:D
cheers mikee55 |
| audiobahnkid592 |
| I used two audiobahn aw1200q's and the box is built to perfect specs for ported and it is on of the loudest setups I have heard. |
| Clipped |
my box is similiar 36"x18"x15.5" (outer dimensions)
i have a slot port down the middle from the top to bottom with a length of 22"...if i extend the port to 29"it hits really low, too low for my liking though, i like a little bit of higher bass.
im using 16sqin of port for each cuft.
you should try making the slot, you wont be sorry... ;)
if you take out the sharp corners and 90 degree angles itll also get louder.
nice job :) |
