diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
my new sub and box - Click HERE for Original Thread
djQUAN
I'm not sure if I should put it here or the subwoofer forum but oh well. :)
still a work in progress.....
the sub (not the best choice but got a good deal) is dual 2 ohm wired in series and driven by amp8 (from 41Hz) at 1500wrms (14.4V into the SMPS) bridged into 4 ohms.
The old amprack along with the huge sub box can't fit together so I took out the rear seats so I can test them for a few days.
the goal was very high output at between 30-40Hz for that BOOM sound. :) for SQ/everyday listening, the sub will be turned off or turned down.
Clipped
nice, which one is the amp8? is the power output as listed or is that dynamic/peak watts?
tried looking on the site but the link for amp8 doesnt work.
have you compared it to othe 1000+ watt amps?
djQUAN
I haven't compared it to other amps since I don't have any. hehehe
amp8 is not visible since it is between the amprack and the sub box. I have other pics showing the old setup where you can see everything. will post later. :)
1500w is the output at short bursts. it can do 1200watts continuously. so I'm not maxing out the sub.
Clipped
i have 2-12" subs in my car by boschman....these subs are pretty good for the price...kills alot more expensive subs out there.
but the tinsels tore that were woven into the spider (which was paper) the tinsels tore at the joint.
so...i put in 2 cloth spiders per sub and doubled up the tinsels(non woven in)
and it actually got louder ! i have a 225hcca @ 1 ohm for the pair
i swear to god this amp is louder than alot of 1000 watt amps out there....
i have 2 hccas, but the one with the Ti opamps i put in are louder...or it may be because of the outputs, the one with the Ti's have 80 volt devices and the other one has 100volt transistors
gonna put this 2150sx on them ... if it ever decides to start working... :)
djQUAN
this sub too........bang for the buck. :)
I installed a setup in a friend's car (same ride as mine) a 225HCCA (the one that blew) driving a dual 2ohm solo S12L5 at 1 ohm and it hits quite hard. much harder than what I expected it to be from 400watts. now I know why they got called "cheater amps" ;)
djQUAN
pictures before I put the rear seats back.....
I had to modify the seat lock handle and extend it since the EQ is blocking the way......
now you see it.......
now you don't!!!!
Clipped
hey man thats pretty tight...thats an alluring glow you got inside that box there....what did you use for a light?
it almost looks like luminescent sheet...very cool
youre making me want to pimp out my install too. :D
djQUAN
I just used a single tube blue CCFL. the same thing used to light up CPU towers. :)
I'm afraid the vibration of the big sub might kill it sooner or later but i have an LED array waiting (but different shade of blue that's why I didn't use it) incase it happens.
luka
Hi
How much did it cost you to get this AMP8 in your hands?
djQUAN
slightly above the cost of amp2. :)
I bought it along with amp32 to save on shipping. :D
djQUAN
my friend made a couple of vids (you can't see me in there. :clown: ) and posted them in youtube.....don't mind the funny looking motion of the woofer cone, the cam phone frame rate messes it up badly. :smash:
http://www.youtube.com/watch?v=KWHNgplwSjk
http://www.youtube.com/watch?v=F0zBi7W7RHg
luka
Hi
HAHAHA best diy evrything ever. Great job done.
djQUAN
notice the tailgate flex? nasty. I feel like it will fall apart soon. :whazzat:
luka
Hi
Go for 2x 15" :D sure even then will not come off or will it :D
djQUAN
nah. one box with one sub is already too big and the alternator is having a hard time powering the sub amp.
so two subs is out of the question. :hot:
djQUAN
dang. after spending quite a bit of money and some hard work.... it finally paid off after trying quite a few times. :clown:
Clipped
man , i really have to clean up my install... :(
Page generated in 0.039028882980347 seconds with 17 queries,
spending 0.00801182 doing MySQL queries and 0.03101707 doing PHP things.
