diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Teac A-L700P Modding Questions - Click HERE for Original Thread
jdubs
Hey Everyone
I've had one of these sitting around for a while now....getting no use and I've figured I would try a few mods.
A couple of questions for people that have worked on this amp. I want to run new coupling caps directly off of new RCAs straight to the amp board.
Can anyone tell me what points on the amp board I need to solder the caps to?
Also, I want to run the output straight to new binding posts. Where are the output points on the amp board that I can wire the binding posts to?
Any help would be GREATLY appreciated!!
Thanks!!
Jim
tripathdude
Solder the directly from the RCA jacks to the positive connection (opposite side of the white band) of where the coupling capacitors are located which is C809 & C808. The stock capacitors are labeled 2.2uf 50v.
There are point ferrite boards placed right after the inductors-- 8085, 8087, 8084, and 8086. The tripath board might invert the speaker outputs so you might try inverting them. I am not positive on this though. You will have to bypass the output relay if you plan to solder at these points mentioned above. I hope this helps.
jdubs
tripathdude
This is very helpful! Thank you very much!
Jim
GJF
I would suggest removal of the second board to lesson the current draw on the SMPS. Makes a useful reduction in heat generated by the chip on that board running idle in a 2 channel system.
The 1000uf 35V cap can be replaced by a Panasonic 1800uf 35V FM series without much trouble and gives a smoother sound IMHO.
It is best to remove the 2 input capacitors and hard wire from the board to some 2.2uf PIO or good PP caps of your choice that you can hard wire to new input skts on the back panel. be careful with the wiring as I found poorly routed wiring caused mine to pick-up low levels of switching noise that could be heard at high volume. Twisted pairs of Teflon insulated silver plated wire-wrap wire worked for me. Drilling 2 small holes in the small board mounted heatsink allows you to keep the wiring as short as possible and to solder the wires to the pads vacated by the removed input caps.
Whilst the heatsink is removed take-off points for wiring to the speaker jacks can be implemented by connecting to the relay contacts and relevent points on the ferrites as previously mentioned.
Be careful with the heatsink removed to not wipe the heatsink compound all over the chip pins and ensure none of your new wiring can short to the heatsink when it is refitted. I actually removed the motherboard that the 2 amp boards plugged into and removed the cheap and nasty connectors used and hard wired the remaining amp board with solid core cable using the original connector fixing holes. Pig to refit everything but that and the Panasonic cap and 2 PIO's made for a much better soundin amp IMHO.
Puffin
Are these amps still available ? Have they ever been sold in the U.K and are they worth having and tinkering with. I seem to remember Decibeldungeon modding one of these.
sts9fan
I just picked up one of these guys off amazon because I am loving the tripath sound. So what caps have you replaced? With what?
Kris
vse
hi puffin,
I have a new teac al700p still in box, not plugged in to mains yet. if interested pm me.
Puffin
vse. I tried to pm you, but I am told (by the moderator) that you will not accept pm's through diyaudio ? How much do you want for it ?
Rob.
vse
ahh that's odd ,I have selected yes in edit options for my private messages. anyway email me : v.esa at dot co. uk replace at & dot with usual and i'll get back to you.
Puffin
vse. You don't seem to have sent me the name of your internet provider to complete the email address ?
vse
oops sorry, hear it is: hotmail
Puffin
vse. I have tried v.esa at .... co.*k, but it has not been delivered.
"unknown address error"
vse
don't know whats happening, please try again. v.esa@hotmail.co.uk
BWRX
quote:
Hi vse. In your user options select no for the "Hide Email Address?" option. That should enable your email button.
vse
thanks brian, .... done
Puffin
vse. I have niot heard from you ? Did you get my pm ?
vse
no, no pm are you emailing me on my email address in post 13 ?.
Puffin
vse. Yes and I also tried your pm at diyaudio. You can email me here.
vse
puffin, I am receiving mail from others on my email address, must be something at your end, I cant pm you here ether as your pm is not active, can you forward your email here.
Puffin
vse. email me at rhpowell@webandmail.co.uk
Page generated in 0.037734031677246 seconds with 17 queries,
spending 0.00758600 doing MySQL queries and 0.03014803 doing PHP things.
