diyAudio.com diyAudio Forums Archive > Top > Source > Digital
To superclock or not? - Click HERE for Original Thread
dublin78
Hello
I have a Monica2 NOS DAC that reclocks the spdif signal. See http://diyparadise.com/dackit/1545bdackit.html
Is there any point adding a superclock upgrade to my transport, if my DAC reclocks? I suspect that the reclocking is minimal???
Any suggestions?
dublin78
Apologies.
RE: My DAC: "it has asynchronous reclocking of the 3-wire eiaj signals".
I do not understand what this means though.
analog_sa
quote:
Originally posted by dublin78
Apologies.
The 3 lines from the 8414 get clocked through a D-type flip flop at 80MHz. This makes the signals synchronous with the 80MHz clock and improves jitter but probably leads to data errors.
I have no idea if improving the transport will be worthwhile
Guido Tent
quote:
It is. The reclocker in the DAC is an attenuator, less jitter in means less jitter out
when upgrading your drive with a new clock, make sure the SPDIF signal is reclcocked again as well
best
Page generated in 0.019656896591187 seconds with 17 queries,
spending 0.00741768 doing MySQL queries and 0.01223922 doing PHP things.
