diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
ZV9 or F2 for Fostex? - Click HERE for Original Thread
kenev
I need your help deciding on which transconductance amp is most suited for driving a pair of Fostex drivers.
I have a pair of FE167E in TQWPs (aka Voigt Pipes) and also a pair of FE206E waiting for a pair of BLHs to be built. Having read Nelson Pass's paper on current driven full-range drivers, I have already built a vacuum tube transconductance amplifier, which sounds absolutely marvellous with the Fostexes.
But, I also want to build a solid state transconductance amplifier. So, having read a large number of posts here, I will have to decide which of the two mentioned (ZV9 or F2) would be better suited for my case.
Any help from the experts here will be welcomed.
Evangelos
vitalstates
Hi Kenev
I'm sorry I can't answer the question but I'm about to finish an F2 to drive a pair of 206E voigt pipes (see web page).
But I am intrigued by your mention of transconductance valves....any chance of some detail??
Ed
kenev
Hi Ed,
Here is a link to the mentioned amplifier:
http://www.audioasylum.com/scripts/...gnequest&m=5167
I have made a change to the original schematic: I use a ccs fed shunt regulated voltage supply for the screens, using Gary Pimm's CCS and a stack of 0A2 and 0B2 VR tubes, for about 255 volts between screen and cathode. Sounds much better this way.
Originally, I had built the lower power EL84 version (ca. 2.5W)
http://www.audioasylum.com/scripts/...gnequest&m=2553
but there was a lack of power, more evident on loud passages and dynamic parts, so I went for the higher power version. Note that, even it is titled a "9W amp", to get those 9 watts, you have to increase B+ to a much higher voltage in order to increase the tube's power dissipation to 36W. With a B+ of 450V, as shown, power dissipation is 24W, so output power is around 6 watts, not bad for a Fostex. I'm using KT88s. Had tried EL509s, but there were producing a lot of distortion.
Evangelos
Vix
ZV9, if you can obtain the Jfets. If not, an F2 will work.
Brett
Evangelos, I'm curios about your tube amps, but can't get into the AA links provided. Could you post here or provide other info on them please?
stefanobilliani
The ZEN V9 is cool becouse with a couple of switches you can alternate between current source and voltage amplifier . And choose for yourself or sometime also for the music you are listen to . In courrent source mode dont forget to load the output with a power resistor wich is 22ohm for the FE206E .
Use the best ( non inductive ) power resistors avaiable , and match well the J fets
:cool:
kenev
quote:
Brett, I just tried the links mentioned above and they work fine. I don't know why you can't open them. Maybe you could try again.
Brett
Works fine now. It asked for username and password before and then rejected my valid AA info.
Cheers.
kenev
Cheers.
That's good. Have a nice reading!
Evangelos
Page generated in 0.029177904129028 seconds with 17 queries,
spending 0.00768495 doing MySQL queries and 0.02149296 doing PHP things.
