diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Diamond Audio D6 1500.1 manual? - Click HERE for Original Thread
mbayaq579
I have a Diamond Audio D6 1500.1 and I was wondering if anyone had a paper or pdf version of the manual for this amp or could at least help me figure out a few of the buttons, ie if in or out is 0 or 180 deg for the phase button etc etc. Any help? Thanks.
justonemoreamp
The 0 or 180 Phase switch is used for the purpose of reversing the signal phase of the bass signal for rearward firing woofers. It also "Might" be used to bridge two amps together like my Early Rockford 250M's.
I am not sure about your amp so don't go bridging on this posts info alone, you might damage your amp severely. :)
mbayaq579
Ah, thanks for the info man but I was more referring to the fact that the amp does not clearly mark which position of the button is 0, and which is 180, I just want to make sure I have it at 0 lol. That was just one example too, some of the other dials like the crossover freq knob dont have Hz markings on them to tell you what you are setting the crossover to, something else the manual would probably help me figure out specifically. thanks tho
Page generated in 0.016932964324951 seconds with 16 queries,
spending 0.00770426 doing MySQL queries and 0.00922871 doing PHP things.
