diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
transistor question - Click HERE for Original Thread
mike49504
im working on a amp and the ouputs i need are marked a1941 and a c5198 wondering if i might be able to find a replacement of theese two parts they are made by toshiba i have tons of c5200, 2sa1943,2sc5359 wondering if any of the parts i have will work in place of thoose 1941's and 5198's if someone could please help i would greatly appericate it
Perry Babin
The 5200 is much larger than the originals but if you have enough space for them, they should work.
mcminone has the originals.
mike49504
the 5200 will work for both a1941 and c5198? or just the c5198?
i have alot of 2sc5200's in stock and 2sa1943'
Perry Babin
You can't replace a PNP with an NPN. I should have been more clear.
The 2SC5200/2SA1943 pair would replace the original pair.
PacificStereo
I'm pretty sure that I have the original semis, if you want them. I'll be at the lab on the weekend and I can check for you, if you'd like.
-Pacific
mike49504
ok sorry i cant think today will the c5200 hundred replace the c5198 and the 2sa1943 replace the a1941 is that what u are syaing or no? i cant think im having a bad day sorry
Perry Babin
Yes, if they will fit into the alloted space.
PacificStereo
I guess you're not interested. Good luck with the subs!
-Pacific
rhtatro
Would you have a schematic or service manual for the reference 650fet r receiver? I have one that is a real neat piece of gear but it has a problem: I get sound out the speakers only if A an B speakers switches are on, and when I up the volume, it has severe distortion untill the protection kicks in. I have new mosfets on order.
Any ideas about this? Thanks!
Bob Tatro
PacificStereo
Hi, Bob!
You know, I don't think I have EVER come across a 650R, not even while I was fixing audio for Pacific.
I will take a look at what I have over the weekend and get back to you. Don't expect much. A lot of the service info for the proprietary Pacific stuff was photocopies, factory notes and institutional knowledge. But I may have it on microfiche.
Let me see what I can find out.
-Pacific
Page generated in 0.026827096939087 seconds with 16 queries,
spending 0.00789213 doing MySQL queries and 0.01893497 doing PHP things.
