diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
mtx 1500d - Click HERE for Original Thread
mike49504
im working on an mtx 1500 d and not sure what goes in 2 locations c 63 and c 64 i think they are resistors but not sure what value they might be some on the board are 68j63 not sure if there the same for the locations noted if anyone could help i would greatly appericate it thanks
Perry Babin
1500d or 1501d?
Most of the caps (prefix of C = capacitor) have their circuit board designation under the component so you may need to post a photo to get the value.
mike49504
the amp is a mtx 1500dx locations c64 and c63 tryed to load a photo on here but for some reason everytime i try if says the file is to big
Perry Babin
I don't have anything on that amp. From the outside, it looks like it may be similar to the 6500D.
If you don't get any other responses...
Download a program named Irfanview (irfanview.com). Load the photo in Irfanview. Resize the image to 640x480 (IMAGE >> RESIZE/RESAMPLE). Save it as a jpeg with a quality value of 85%. This should get it below 100K and then it will load. Change the name so it doesn't overwrite the original.
To crop the image, select the area you need to save then ctrl-y. Resize (if necessary) and save.
Page generated in 0.019512891769409 seconds with 16 queries,
spending 0.00751877 doing MySQL queries and 0.01199412 doing PHP things.
