| Skorpio |
The tray will not open or close. If it is helped a little with a finger I will move, but not without....
It could lack some oil or lubricant? What to do? |
| tone arm |
| hai, iv been thru with diz kindof problem before, what i did was get the tray motor replaced and it works. you can source the motor from any philips cdm4 tray mech. good luck. |
| Skorpio |
Where is the tray motor and is rework possible?
Dont think it is gear because it can work with a little help....? |
| Skorpio |
| Belt seems ok......but perhaps tension on it? |
| Skorpio |
When I opened the played a part was loose inside. With a little shake it fell out. It was a little metal pin or axle....2mm in diameter and 10-11mm long....with hard surface...like a capstan axle on a cassette player.
Anybody know what it could be? Possible a part of the tray mechanism? |
| Skorpio |
It seems to be the two belts, the motor is running but they do not move the wheels....
Anybody knows the types? |
