diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Really elementary question about caps. - Click HERE for Original Thread
G
Hi all. I have a rather simple question that I should already know the answer to but I'm unsure. Say I was building a PSU and I needed to have a set amount of capacitance per section. Would paralleling several smaller caps to reach that amount rather than using one big capacitor lower the impedance of the section? It seems that it would but I want to be sure.
Mikael Abdellah
If my memory is correct, the short answer is: Yes. alot of smaller caps will give you less impedance. I think there are a few threads that better explains it.
G
quote:
Thanks Mikael. I suspect it is the same as paralleling several resistors which would, of course, lower their combined resistance.
amplibang
I don't trust my judgement either but I think it should. Better check out an electronics shop to erase your doubts.
_________________________
McIntosh MA6900 Integrated Amplifier - Download the MA6900 Integrated Amplifier Catalog by McIntosh Laboratory, Inc.
ArtG
Paralleling caps is the prefered way to do what you wish to do. The tradeoffs are cost and complexity.
Page generated in 0.020768880844116 seconds with 17 queries,
spending 0.00788832 doing MySQL queries and 0.01288056 doing PHP things.
