diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Anyone build/use 6BG6G? - Click HERE for Original Thread
kegger
I'm currently running some in push pull UL at 410v and 40ma.
Can't beat um for the price, pretty much free these days and sound nice. :)
Just curious if anyone else has experimented with the 6BG6G and what they found.
burnedfingers
Almost identical to the 6L6 except it has a plate cap. SY has made mention to this tube. Vacuumtubes.com sells them. I bought a quad of them with the adapter bases and they work fine in my Wurlitzer organ amps in place of the standard 6L6GC's.
The adapter bases are needed in order to replace the 6L6 in a socket wired for a 6L6. There are several connections that are different.
SY
I've used them in two amps in place of 1614 and EL34 (an Eico HF87 and Fairchild 260). They appear to be identical (except for basing) to the rugged and low-distortion 7027A. I've bought LOTS of them.
kegger
At the moment I'm using just the G version (ST shape) not the GA.
Yep got them adaptors! I've been collecting up the ST/Coke bottle
shaped ones for a while now, also have 2 of the GA quads from the
vacuumtubes site.
I originally went on this quest when I acquired a pair of Acro TO-300
outputs as they seemed a perfect match and the ST ones just look cool.
I just hope I'm not pushung the the 20watt plate version G to hard. :)
Again the data sheet gives a pretty low screen rating on these tubes also.
Well time will tell, but they sound dam good to me!
Tom Bavis
I think you're OK in UL or triode. I'm thinking of using these with Dyna A430s at about 400V. Backup plan is of course the GA version... since I have about 40 of each!
tubelab.com
I have "smoke tested" a few of these tubes. Beware, most 6BG6 tubes (anything with a coke bottle shape) does indeed have a 19 watt plate rating. They really don't like being pushed beyond this. These do have the same guts as a similar vintage 6L6GB, 807, or 1625 and can usually be substituted for them. The maximum screen voltage rating is 300 to 350 volts (depending on whose data sheet you are reading), which is higher than a 6L6GB of the save vintage (250 to 300 volts). I have cranked them to 400 volts without issue, but watch the plate carefully if you are near 20 watts.
The tubes that VacuumTubes.com sells are from the era where vacuum tube sales were declining and some manufacturers stuffed glass with whatever guts that they had to fulfill contracts. This era produced a few rather strange tubes like 6B4 (a DHT) glass filled with 6AV5 guts (a beam tetrode sweep tube). In this case there are 7027A guts inside an envelope labled 6BG6GA. These tubes are "super 6L6GC's" in a 6BG6 bottle. They can take 35 watts and 450 volts in triode with ease.
kegger
Sounds good, thanks guy's.
Tubelab, (yes I will watch them) but how'd you feel about the 6bg6g's
running at 410v ul and 42ma for a plate disipation of roughly 17watts?
tubelab.com
My small bench power supply only goes to 400 volts, so that is the upper limit of most of my testing. I ran a bunch of different tubes in SE (triode and UL) at voltages up to 400 volts. I was using fixed bias, so the tubes were seeing the 400 volts less the drop in the OPT. I cranked several 807's and 6BG6G's up and there seemed to be no issue with the voltage, but the plates began to show a dim glow in a dark room at about 20 watts, others showed no color at 24 watts. I get the same results from 6L6GB's from the same era. I would guess that 410 volts is probably OK, but I have not actually gone that high.
If you are using cathode bias, or have a lossy OPT, you are probably not hitting the tubes as hard as you think you are.
I did have one 807 die in a fireworks display, but these tubes were badly mistreated by a previous owner. Almost half of them were physically broken. I am assuming that this one had problems, since it sparked out before I really cranked it up.
kegger
I hear yu thanks!
Appreciate all the torture testing you do, saves some of us from doing it. :)
(Running fixed/adjustable bias with 12ohm cathode resistors)
Yah I got roughly 410-412 on the tube pins them selves, but this is in an amp
that isn't the final one I plan on using these tubes in so I'll tone down the voltage
a bit on the final rig that these will be used in, I do see a very small hint of a rosey
edge on one spot of all the tubes when there run that hot so I think I'm pushin it a bit.
These I'm running right now are RCA, I have a bunch of others that look quite different as
far as the plate structure goes with heavy ceramic looking inserts and strengthening rods that
I am going to run and see if they react about the same way as the RCA version of the 6BG6G do.
I cranked the heck out of the GA's from vacuumtubes.com with no signs what so ever, only tested 4 of the 8.
frank754
Quick question regarding this, and old Fender guitar amps.
I see some vintage Fenders used 5881's.
Are 5881's fairly close in specs to a 6L6GB or GC?
Specifically, if I use a pair of these super 6BG6G's in a re-creation of a Bassman, for example (with the correct pinouts & plate caps of course), can these be directly substtutued for the 5881's called for, with the same component values, or should this be optimized?
The schematic shows 432v going to the CT of the OPT, then to the plates,
430v going to the second grid (less a 470 ohm 1 watt resistor's voltage drop from a common point to each one of these grids), and
-48v bias going to a pair of 220k resistors (split to have the result of one of these going to each of the first grids, and there is also a .1/400v cap coming in from each of the plates of the last pre-stage 12AX7 to these points (the triode grid),
and then cathodes of these output tubes directly grounded to B-
I'm working up a parts list, I'd like to keep the output stage original as much as possible, just add mods to the pre-amp stages, not here.
kegger
5881's are a strangely rated and built tube where some are upto the
spec of a 6l6gc and some are rated more like a 6l6gb and can't take the
abuse a gc can, I've been there and done that with a pair of GTA SE-40's.
So I would not trust a 6BG6G in the situation you are describing and the
requirements of the circuit, nor would I use a lot of the 5881's out there.
But the tubes you get from Vacuumtubes.com with the adpators, naimly
those GA versions should work just fine in your app.
kegger
Well after testing then running a lof of different internally shaped tubes
I think I've come to a few conclusions. (6BG6G that is, at least 10 samples)
1. The side getter variants are probably best to stay away from as they
seem to be very unstable and vary quite a bit from tube to tube, plus take
a lot more bias voltage then all the other variants, more then my test amp
is capable of without changing a resistor in my bias circuit while all the others
bias up just fine and are basically in my center position so a big difference there.
(these tubes just give some readings and actions that make me weary of them)
2. The shiny black plate versions with several pieces of white ceramic spacers
and strengthening rods seem to be a beefier tube then the standard charcoal
plate versions without the rods or ceramic.
Listening tests will be performed when all other testing and selecting is finished.
kegger
In case anyone likes pic's, here's my mess at the moment.
Page generated in 0.24088501930237 seconds with 16 queries,
spending 0.20388293 doing MySQL queries and 0.03700209 doing PHP things.
