| which pass amp "current" amp, which voltage? - Click HERE for Original Thread |
| ShanaVar |
just to clarify, which of the pass amp is a "current" amp and which a "voltage", as i want an amp playing with 2 way and i dont want series xover (maybe aleph?)?
thanks,
Patrick |
| GRollins |
The Aleph amps are voltage amplifiers, as is the Aleph-X, the A-75, the Zen variants...basically, you have to go to the First Watt amps to find a current amp.
Grey |
| Netlist |
Anyone correct me but I believe only F1 and F2 are current source amps.
/Hugo |
| ShanaVar |
hmm, i just finished the original zen, except the mounting of the boards, but case and everything, and i didnt finish it, because i got in my mind(think i read it somewqhere....) that it's a "current" amp and i cant drive 2 way as well as with an voltage amp. and as i dont want to do a case 2 times, and the parts havnt really been expensive i asked =|
so maybe i'll finish it or just go for some aleph IF it's only the Firstwatts being current amps. would be great news :)
thanks & regards |
| ShanaVar |
| what aleph would you go for with a budged of 150-200€(i need about 40-50w@8)? (got the sinks &case,plugs etc.) as matching fets where one costs 5€(i.e. irfp044) could get exp :| |
