diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Is this a FM aerial? - Click HERE for Original Thread
johnthedoctor
Dumped in an alley close by, probably a victim of the gales at New Year.
Is it good for FM radio?
AndrewT
measure the directors and reflectors.
If they are about a foot from tip to tip then it is a UHF TV aerial for bandA
A bit shorter and it works for higher frequencies, Band B upwards.
If the tip to tip are about 5feet then it might work for FM but it's going to be damned heavy to lift up to the roof. I have never seen a high gain FM aerial with that many elements (39 if I can still count).
Page generated in 0.014569044113159 seconds with 16 queries,
spending 0.00674963 doing MySQL queries and 0.00781941 doing PHP things.
