diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
WTB: Morel MDT 33 or 33SE matched pair - Click HERE for Original Thread
KBK
need a set new used, or only used to listen to gregorian chants on sundays.
Let me know, I'll be buying soon.
KBK
bumpity bump.
DSP_Geek
How about a pair of Supreme 110?
KBK
do they come with a nice Bernaise?
Are the as good as the MDT 33's?
We modify the tweeters and the boxes are made to spec for the 33, and at great expense, I might add.
We already have a sensitivity mis-match. We need MORE sensitivity, not less. The only way we can have a passive crossover on the current model, is with separate amplifiers of specific sensitivity.
If I can fully dismember the 110's (even the metal backing/cover must be removable) and a standard 33 faceplate can be attached, I might go for it. All our systems are going out the door in active form, at the least. So the sensitivity issue is not that critical.
OK. I did some looking. If I can peel that cover off the motor, I might take a set.
This series of tests was a bit limited, but I think a couple of preliminary conclusions are justified. Overall, the mdt33 goes lower than the 110, and has less overall IM distortion, at least at the frequencies tested. There are holes in the data though. Also, the mdt33 is very smooth on axis with very good off axis curves. It will be interesting to see what DLR gets on his baffle. The other impressive test result of the mdt33 is it's remarkably better second order numbers. In general it seems to be one of the best, if not the best in terms of second order products. The low end excursion of the mdt33 is clearly at the top? maybe the top.
http://www.markk.claub.net/Testing/..._supreme110.htm
Maybe not. MDT is still the king.
KBK
Dude who made MDT33 offer:
YOur spam filter is giving me the boot.
It might be the goo bit in the email address. Apparently..it might end up being assocaited with...porn! :xeye: never whouda guessed.
KBK
Love those MDT-33's!
Want some more!
Anyone got a set? yum! :lickface:
Page generated in 0.023036003112793 seconds with 17 queries,
spending 0.00806689 doing MySQL queries and 0.01496911 doing PHP things.
Please support our sponsor.
