diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
PG Titanium 800.1 refuses to work - Click HERE for Original Thread
valterdaw
With not much success I am trying to fix PG Ti 800.1 amp. Power supply worked from beginning. I noticed, that small SMD LED's on driver's part of board were both off. Flexed a board a little, they lit up - bad contact. Inspected with magnifying glass - nothing, resoldered all SMD's - now both LED's are always on until I flex a board little harder :confused:
But amp still isn't working right - it started to amplify signal, but output is very low and distorted. Q114 transistor (C4793) is getting pretty hot very quickly. Checked all SMD's & TO92's on driver board - all seems to be fine. I appreciate any help. Thank you.
Perry Babin
Have you tried to get the schematic from PG?
Bertje
Recently I repaired a PG TI 500.4. Check all the resistors, some of them are like fuses (infinite resistance).
Rob.
justonemoreamp
quote:
PG does not release documents. I have friends that work there and still no doc's..:) :) :)
PG has very reasonable flat rates. See linky below
http://www.phoenixgold.com/2004/flatrate.html
valterdaw
Hehe, no way ;)
Spent about 6 hours working on it :eek: and... it works!!!
List of what was wrong:
- 1 leaky transistor on driver board
- 1 open and 2 significantly out of spec resistors (thanks, Bertje!)
- damaged trace on board
I am happy :p
justonemoreamp
When you mentioned your flex issue was when I thought it was best sent to PG. Thats a tough thing to tech out on the internet, you did well.
Congrates on your successful completion of repair you saved a bunch of money, and time shipping. :) :) :) :)
Page generated in 0.023837089538574 seconds with 17 queries,
spending 0.00787163 doing MySQL queries and 0.01596546 doing PHP things.
