diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
8x Mur 860 strong enough for 2 paralleled 4780? - Click HERE for Original Thread
Bassterror
Hi
see topic. 2 Lm4780, each with paralleled outputs running on 25V secondarys, about 35V with a 4 Ohm load.
OK??
If not: what about RHRP 1560 (15A/600V/35ns, TO-220 compared to 8A/600V/30ns, TO-220)
What are ur experiences?
Bassterror
No Idea?
I've got 860 here, but not for both...
halo0925
MUR860 working peak reverse voltage 600V
Average rectified forward current 8A
Repetative peak surge current 20khz square wave 16A
I think it will be plenty;) worse case heat sink them:hot:
Bassterror
Hi
thanks for ur estimation.
They can handle more current then the transformer so i think the rectifier is not the first thing to start burning...
But i see man people using 8 Murs even for a single 3875:D
I'll try:)
halo0925
They are useing dual tied rectifiers from a dual output transformer, to help stiffen and reduce 60hz humm...... most of the single chip amp power supplys like Brians or Peters work on the principle of power transformer and rectifier overkill and reduction in power supply capacitance.:D
Page generated in 0.020193099975586 seconds with 16 queries,
spending 0.00862312 doing MySQL queries and 0.01156998 doing PHP things.
Please support our sponsor.
