| carstereogeek |
Can anyone suggest chipamps that will run on a +12 volt supply? This will be used in an automotive 5.1 system I'm working on.Space is a major concern and available 5.1 car amps can sink a battleship!
Thanks for the help! |
| Dxvideo |
| You may use Philips's TDA1560Q.. It works in class H and can give up to 40W RMS. Noise and THD values are not comparable with conventional chip amps but it works fine. |
| Dag |
The TDA7560 is an extremely good caramp.
4x28W (2ohm&12V) and VERY low dist. Peak current is 10A!!!!
The TDA7561-7566 are cheaper but also good but you need to do some programming.
D |
