diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Temp Variations CH to CH - Click HERE for Original Thread
Zero Cool
What would be a normal channel to channel temprature variation range?
I just finished my amp and one channel (the stock factory ch.) is running about 101-102 deg F, the repaired channel is running 104-105 Deg F so we are not talking about much 3-4 degree's max.
At what point do you say, ok im cracking the cover open again and checking or resetting BIAS?
Zc
Page generated in 0.014825105667114 seconds with 16 queries,
spending 0.00780916 doing MySQL queries and 0.00701594 doing PHP things.
