diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
NEW KT66's - Click HERE for Original Thread
Trout
Picked this new up over at a guitar forum,
Finally, JJ has a New tube that offers a golden ray of hope
The KT66 http://www.eurotubes.com/euro-u.htm
Lets hope it sounds as good as it looks!!!
Kudos to JJ
Trout
JandG
My best amp is a Whitney DV-66. A kt-66 amp,, with dual rect, hi-lo, modern, vintage, w/ vari-slope @ 22k- 33k- 47k- 56k. I just frinkin love kt-66 amps..Got Gt's in there now. I will try these.
Klimon
What about Chinese kt66, I heard those are good (for hifi atleast)?
Simon
Jim McShane
quote:
Simon
They are. And JJ build quality is rough, to say the least. 66% rejects in my last KT-77 batch...
Trout
quote:
66%???
Out of the last hundred KT77's I have bought, I had 3 bad ones, Are you buying direct?
Or should I say 5 bad ones because I fried the screens on a pair lol
I Find 66% rather hard to swallow, But Your a Tube dealer and I guess your right. I have experienced a similar reject rate with New Sensor tubes.
I have however noticed ( Not Saying you Jim, Because your rep is outstanding) it is very common amoung tube dealers to slam JJ tubes. I see this a lot on many musician forums, Each one has its tube " Hero" for NOS and other quality tubes, But JJ is one of the worst slammed products.
Is that because of sour grapes over the original pin problem? Or are they leaking out seconds to cut rate distributors like New Sensor does?
I have experienced close to the same 66% reject rate with New Sensor. I stopped buying anything New Sensor makes entirely.
Trout
Jim McShane
Here is a post I recently made in another forum regarding the KT-77:
"As promised, I got another sampling of JJ KT-77 tubes in yesterday and today I examined them. Let me offer a word of advice - forget the KT-77, I rejected 66% of the tubes I got due to abysmal build quality.
Here's the reasons:
1. Almost all had crooked bottles - not just slightly off, but some were so crooked I actually burst out laughing when I saw how bad they were!
2. On some tubes I found burn spots on the glass where they don't belong.
3. The top edge of the tube bases are all nicked and gouged.
4. The base pins are soldered poorly, and the pins themselves are crooked in the base! You know how a 9 pin tube sometimes has bent pins? Well, these KT-77 pins are so far out of alignment in many cases that they won't allow the tube to be put in a socket!! I'd have to get a heavy needle nose pliers and carefully try to bend the pins back into alignment. Plus the pin tips often have sharp, squared-off edges, and this will tear up a socket.
5. About 10% of the tubes in my sample still have the small pins! Amazing!!
What's even more amazing is pin diameter on the same tube varies by over 0.005" on a number of tubes. Between the crooked pins and the pin size variation these tubes will be murder on your sockets.
They might sound good, but these tubes are appallingly bad quality. This sample had virtually the same problems as my sample from last spring (there is a bit less loose material in the bottles, that is improved); therefore I would not use them in my own gear. And if I won't use them in my own gear then I won't carry them. Note that the total size of both samples is around 50 tubes."
My rejections were based on build quality, not electrical performance. I wouldn't use those tubes in my own gear, so I won't ask someone else to put them in theirs.
The reason JJ stuff is so often disliked is simple:
1. The ECC83 family tubes they build are VERY often microphonic. As well, one triode tested weak quite often. The reject rate on their ECC83S was up at about 40% when I gave up (and I'm far from the only one who did).
2. I had to scrap 60% of the initial shipment of the JJ 5AR4/GZ34s due to internal miswiring. As well, there have been many reports of shorts and fuse blowing with this tube. I have to VERY carefully test them at rated current before I'm willing to send them out.
3. The pin diameter fiasco - which was present on all JJ octals, not just the KT-77.
4. Remember the neat red base on the early JJ 6L6GCs? Well, it disappeared, and it was replaced with a poorly soldered cheap base that often features a top end full of chips and gouges
5. Loose material and unusual deposits of various sorts show up inside JJ power tubes routinely.
If you bought JJ tubes from me, would you want tubes that featured the "issues" above?
The JJ EL84 and some others are quite good. I wish they were all good, as I would like to sell them all. But I can't abide by the level of build quality they pass off.
I don't buy direct - I would, but dealing with rejects is VERY costly when they have to go back to Slovakia. And I can assure you that it isn't a distributor thing. I have had many reports of JJ stuff bought elsewhere (since I don't carry much of it) - including the US dealer who has a pipeline to the Jamona and Jurco families - that are consistent with my experiences. I've bought JJs from multiple sources too, and all have had "issues".
FWIW, my reject rate on the New Sensor tube families is well under 5%, in some lines it's about 2% is all. They do a great job - they didn't always but they do now and they keep getting better. The one exception is the 7868 - the pin diameter is simply too large for a fresh novar socket. It's great for taking up slack in a worn one, but once you use an EH 7868 you can't really get good contact anymore with old stock stuff.
Anyway, that's my viewpoint on the whole situation.
SY
That's disappointing. I've had excellent experience with their EL84 and ECC81, the latter being far and away the best of the species I've ever used.
Trout
Great Write up and response Jim!!
Its kind of Ironic we have had similar experiences With opposite companies in many of the listed issues.
And I bet we only live about 2 hours apart.
I only resell a minimal number of tubes as tube onlys, Generally mine go into units being sold.
I gave up on New Sensor VERY Fast.
So I am sure I have some sour grapes over that investment.
Especially in a flat of 12AX7LPS and 5Y3's
I generally only buy JJ's KT77's, 34L's, 6L6's and ECC83's and have had great luck.
I have seen a number for leaning towers in both the 77's and 34's
But nothing totally outragous. I have seen that even in some of my NOS collection.
But all of you comments are noted and I will be watching these more closely also.
Trout
coolmaster
Reading your views, I'm now hesitating on my next purchase of quad set of either JJ KT66 or KT77. My clone Mullard amp can be fed with any KT66, KT77 or EL34, optimized by swap of cathode resistors. In practice, the amp is almost entirely on JJ tubes and so far so good for 3 years now (GZ34, EL34S, ECC81, except the front end RCA 5789)
I just can't get any JJ KT77 here in South East Asia, and at reasonable prices. I just happen to luv the JJ sound.
Jim McShane
quote:
Hi Sy,
The EL84 is fine - I stock them and am glad I do. Thje 12DW7 (despite it being such a close cousin to the ECC83) seems fine.
I have a good supply of NOS, so I haven't dealt with any new production as yet so I'm not able to comment on the ECC81.
richwalters
Nirvana.......I do tend to drop things.....I accidently sent a NOS 807 on a hard carpet....and nothing internally had altered electrically or mechanically. ....a KT90 also went the same path and the mica fragmented as well as a shorted g2 to cath. Anyone dare mention Crappie Ei quality ?
richj
Bas Horneman
I got two KT-77's from my local dealer. Great sounding tubes and have had no problems. However the 5AR4/GZ34 I got from JJ sucked..
richwalters
Can't make it out.......why don't KT77 users fit 88's instead unless there' a space problem ?......The 88 is a beefed up version & would last longer in the same circuit.
Bas Horneman
I dropped an EL34. So I went to my local tube vendor and thought hey. Let's try a KT77. My cashflow situation was not very good..and the KT77 is half the price of a KT88,
Trout
Welp,,
I have A Few KT66's on order, ETA March. Hopefully they will meet my need, If not? Well there are others to choose from.
Trout
anatech
Hi Gene,
Give 6L6EH a try in there as well. They've been good for me so far.
-Chris
Trout
quote:
Originally posted by anatech
Hi Gene,
-Chris
Normally Chris, I would jump on your advice in a heartbeat, But, I added a commandment to my bible about 3 months ago
Thou Shall Not Buy Anything New Sensor. :angel:
Trout
anatech
Hi Gene,
How about if I told you they survive Fender Twins just fine - and last! Also, their 12AX7EH's are great. Really quiet and they also sound very good.
Time to have another look.
-Chris
richwalters
Bas # Even though cashflow may not be good #
The reason I mentioned fitting 88's instead of 77's is simply the 88's will have a far longer life in the same circuit even though they are more expensive. In some AB circuits, fitting a larger tube can result in lower distortion with other benefits without major surgury plus a slight increase in heater ciurrent.
Since tube stuff isn't getting cheaper......I design all my amps for longevity (and this should be the benchmark) and the only way you will get this is by fitting larger tubes running at modest currents. OMO
SOmeone should be told at New Sensor that the FE is producing better quality (!)
richj
Page generated in 0.053385972976685 seconds with 17 queries,
spending 0.00877261 doing MySQL queries and 0.04461336 doing PHP things.
Please support our sponsor.
