diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Transformer Windings - Click HERE for Original Thread
impsick
i need some help. i did as stated in ILP pdf and immediatly popped a fuse. as you can see on the left there is an orange, brown, black and light pink (which im guessing is white). right next to those are another bunch of the same color code but there is a little yellow w/ green stripe wire with them, which the pdf states nothing of. i did the first config. and blew a line fuse once i hit the switch. what could i be doing wrong? there is so many wires, i think it was a custom torodial cuz the pdf doesnt mention most of them.
anyone have an idea? i'd much appreciate it.
Tony
hi,
your schematic does not jibe with the actual transformer as per your picture.
if i were you i'd proceed as follows:
1. i will connect a low voltage, say 6volts ac to any of the secondary windings.
2. measure voltages on the other windings. then i will connect those primary wires so that voltage from end to end add up.
looks to me you have dual primary windings with taps, (just a guess), the green yellow wire could be the electrostatic shield.
AndrewT
build yourself a mains bulb tester.
Use it every time you want to switch on a new build project or maintenance/rebuild project for the first time.
The in series bulb prevents large currents flowing from the mains.
If you have wired the primaries of the transformer incorrectly, the bulb will glow bright absorbing the mains voltage and passing just a few volts to the bad appliance.
impsick
ok guys thanks i'll give it a shot. i emailed the company with a pic and p/num. a few days ago but they never replied so screw them. i'll be back if i have more trouble. but 1st i will make what andrew t just mentioned. thanks again
impsick
Andrew i just did a little search on mains bulb tester and came up empty. do you know of a site? i'll keep searching but if you know where i can go that would be cool
AndrewT
I just entered "bulb" in search for items and "andrewt" in search for user name and came up with 59 references on this Forum.
Others have written about it and drawn it.
I found out about in this Forum and use it "EVERY" time.
impsick
sweet thanks
Page generated in 0.023459911346436 seconds with 17 queries,
spending 0.00810766 doing MySQL queries and 0.01535225 doing PHP things.
