diyAudio.com diyAudio Forums Archive > Top > Market Place > Vendor's Bazaar
New Ta2020 Amp From Taiwan - Click HERE for Original Thread
jtjames
here is a new class t amp ,based on ta2020.
the KINGREX T-20 AMP.
from 41hz audio
KINGREX T-20 AMP WEBPAGE
Netlist
Nice.
Any schematics, board layout?
/Hugo
EdT
Any pricing available
Doesn't seem they have any NA distributors yet.
Workmanship seems OK, but still not up to IPC standards and the volume pot looks cheap.
banana
For this size, they could have use the much more powerful TA2022 :rolleyes:
I like the way they solder the RCA jack directly onto the board. However I'd like to see the DC power jack to be on the same side of the chasis.
Does it need FCC &/or UL1950 certificate in order to sell in NA?
fumac
nice one
what about this :)
panomaniac
Kinda cool, I had not seen that one. Looks like all thru hole stuff, except the inductors. Layout look a little loose. Nice looking, tho.
EdT
Alot of these manufactueres have good points and bad points, if they just refine it a little more with better quality workmanship thay can compete with the best of them, parts selection is pretty standard in the electronics industries, just a matter of selection and availability, everything else is up to the designer. I won't be surprise when these companies will rip open a Bel Cantos and copy it part per part soon.
jtjames
"Kinda cool, I had not seen that one. Looks like all thru hole stuff, except the inductors. Layout look a little loose. Nice looking, tho.........."
It is all thru hole design include inductors,but now smt inductors.:)
user can change it by themselves.;)
abiedoodles
exciting!!! im interested of buying one of these cute class d ready made tripath amp, is the sounds better than the diy 41hz,diyparadise,autocostruire kits? and how about this one......
Little Dot T_100 Technical Specifications
Based on the Tripath TA2022 Class T
Continuous Maximum Output: 2x100W @ 4 ohms, 2x60 @ 8 ohms
Frequency Response: 9 hz - 93 Khz (+/- 5db)
THD+N: 0.02%
Micro-chip switching from four different sources
0 to -63 digital volume control (degree of distortion < 0.002%)
Samsung digital (VFD) display
Speaker surge protection: 200VA
Infrared remote control
Dimensions: 380L x 260W X 80H (millimeters, chassis only)
Weight: 7.5 kg
Tube Pre-stage Option with EF92/CV131 vacuum tubes!
abiedoodles
some thread about it in this link.....http://www.audiocircle.com/circles/...p?topic=36395.0
robert1325
these amps look good!
Are they available?
abiedoodles
yes the Little Dot T_100 is available in this site www.diykits.com
panomaniac
That's www.diykits.com.hk Don't forget the HK part.
abiedoodles
sorry forgot the "hk" to the link, hi pano, did you got in hand the Little Dot T_100 do you recommend it? is there any improvement over other class d tripath chip amps?
poynton
quote:
Originally posted by fumac
nice one
what about this :)
I want one.!
How much and where from ??
Andy
Koolthang
quote:
I'll also have them in stock by Feb 15...if i don't sell out :eek:
www.musical.ca
panomaniac
I don't have one yet! But it should be soon. I've been working hard to get one.
My ears in China say that stock is low, they are hard to get. Also reports say that they have a hum problem that the factory has not been able to solve.
I hope neither is true! But hum I can fix, as long as I can get one.
fumac
quote:
Originally posted by poynton
I want one.!
Andy
FROM CHINA
u can mail me :)
Page generated in 0.045141935348511 seconds with 17 queries,
spending 0.00939703 doing MySQL queries and 0.03574491 doing PHP things.
Please support our sponsor.
