| Frequency range of capacitor - Click HERE for Original Thread |
| Hely |
Hy,
There are programs that draws frequency range of capacitor but value of capacitor is fixed and calculated by program, that is program for making crossfires and boxes for loudspeakers.
Is there a program that draws frequency range of capacitor, but i must set value of capacitor? |
| Minion |
The frequency that a Capacitor filters depends on the Impedance if the signal, So for a Crossover for instance a capacitor will filter different frequencies depending on the Impedance of the speaker...
Also for Crossovers Inductors are alo used in conjunction with the Capacitor and the resistance of the Speaker to form a Filter.....
This calculator should tell you what Cap to use and what Inductor to use to filter what frequecny for what speaker....
http://www.the12volt.com/caraudio/crosscalc.asp
This calculator does the same thing but seems Like it is Not just for crossovers but for EQ"s and other Filters....
http://www.opamplabs.com/cfl.htm
Google is your Friend....
Cheers |
| unclejed613 |
| are you looking for a way to measure a reactance/frequency curve to find component resonances???? not really sure what you're asking. |
