diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
Help Me 230vac Smps - Click HERE for Original Thread
sachserjuris
Hello Dears
Please I need you help me with a 230VAC SMPS building with SG3524/25 or TL494 PWM IC. Post anything. Thanks.
SACHSERJURIS
luka
It would be good to know how much power you need, now many outputs, regulation,...
sachserjuris
OK Mr. Luka
I´m building it, but, I´m with problems with the push pull driver and toroids.... I have a old 1.5 inches outer diameter green color toroid, 1.2cm (Ae), and I don´t know how much (many) gauss it is.
I need calculate the number of turns of this ring core and the other, that mosfet gate driver. My SMPS work only in 127VAC and it´s half bridge, 13VDC output, opto-zener regulated, I need some 20Amps, in this moment is only 5 to 7 Amps and the BUZ73A mosfets (so bad) bang!! OK?!
I waiting by your help
Thank you.
Page generated in 0.024027109146118 seconds with 16 queries,
spending 0.00893712 doing MySQL queries and 0.01508999 doing PHP things.
