diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
a pop when i power down - Click HERE for Original Thread
impsick
ok so built the LM3875 with PDaniels pcbs. it s sounds good buy the way.:D but when i flip the power switch to off the speakers do a little pop. how do get rid of that? i dont know where to even start trouble shooting that.
the rectifier board i added the snubber components if that helps. the big caps are 50v 4700uf.
id appreciate any help. thanks
abid_rehan
Though I have never used the chip but its datasheet does not show that it has a popup noise control circuit while powering on/off.
I hope P.D and other experts here could enlighten more however, as far as I am concerned there is nothing to troubleshoot about as in the abscence a popup noise control its natural for the amp to behave like that.
You could also add bleeder resistor on powersupplies.
BWRX
On the first page of the datasheet it says: "Supply under-voltage protection, not allowing internal biasing to occur when |V+| + |V-| = 12V, thus eliminating turn-on and turn-off transients"
If you shut down the supply while listening to music you will hear the chip shut down when the supply caps discharge below around 12V. You will hear a little click but it shouldn't be harmful to speakers. Do you have an active preamp that shuts down at the same time?
impsick
no just an alps blue. but i've been turning the volume down and then i would hit the power switch
burnedfingers
There is a chip amp mute circuit thread. I have a circuit to eliminate the power on power off noise.
Unfortunately it won't apply to the chip that you are using. It will work with the LM3886 however.
impsick
wheres that? whats that? i wanna see
BWRX
It won't help because the LM3875 doesn't have a mute pin like the LM3886.
How loud is the pop you're hearing? When I power down my LM3875 I just hear a click when the rail voltage drops below ~10V. However, I also have opamps in front of the LM3875 that I turn off after the chip's supply discharges.
impsick
its not really that loud. its kind of a click or pop. but where is some info on your curcuit i got some 3886's im gonna put together here.
would changing the value of resistr between the big 4700uf caps do anything? they are .2ohm right now.
burnedfingers
If you read my edited post you will see that I already made a mention to this.
Leolabs
It's kind of strange to me there is a 'pop' when switch off a GC.My DDGC
doesn't exhibit such problem with a pair of 2200uF caps and a LM3875 and a 200VA EI transformer.
impsick
what about the resister on the caps? what is there value?
Page generated in 0.02804708480835 seconds with 17 queries,
spending 0.00813031 doing MySQL queries and 0.01991677 doing PHP things.
