diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
New CSS SD12 Vented Subwoofer - Click HERE for Original Thread
Timn8ter
Hi there.
I thought there might be some folks out there interested in this recent project of mine.
http://www.timn8er.com/cliff_subwoofer.htm
Viking552
Nice setup. Small footprint with a 12" driver. Did you install the BASH300 as is or did you modify the bass boost at all by changing the resistors?
Timn8ter
Thanks.
I left the amp stock.
Were I to do a sealed box a 4db boost at 25Hz would work nicely.
Viking552
Tim, I see that you had designed it to pair with the Emma. I am interested to know if you have tried it in conjunction with either the Ruby or the Rosa.
I also like the idea of the TB3 surrounds. They look just what I may be looking for. As you said it helps to have matched surrounds. What did you intend to match these with? The ELF1.5 you buddy has put them with?
Timn8ter
I played the Cliff with the Emma, Dakini (a.k.a. Adire DDR) and a little 2 way called the Myra-mini (WR125S and HiVi RT1.3).
I think this sub does better with a speaker that can play reasonably deep so the crossover point can be kept low. That would apply to pairing it with the Ruby as well.
A sealed version would probably be a better choice for crossing higher, IMO. Perhaps front firing as well.
The TB3 was my surround design for the Elf 1.5.
Viking552
Thanks. I was thinking it would probably work well with the Ruby. Very impressive work that you have done.
CSS/XBL
Looks like a great design Tim; thanks a lot.
I've also posted the drawing for the sealed version I currently use myself. It's running with the A-400 with 6 dB of boost at 25 Hz.
I have the Reckhorn F-1 and B-1 on order and I think these represent cost effective and unique solutions.
We'll also be posting some other designs shortly and in about 2 months there will be another driver, the SDX15.
Bob
Timn8ter
Thanks Bob.
I tried to get my customer to go with the A-400 but no go.
I really wanted to check it out too.
TerryO
Tim,
Nice job on the Sub! I also like the fact that you're using a Sansui amp in your system, i know I really like mine.
Best Regards,
TerryO
Timn8ter
Then you should really appreciate the fact that it was free!
It is a darn nice amp. My father-in-law bought it in Japan in the 70's (model AU-710 rather than 717) played it once and put it in storage.
Before he moved to Vegas he asked me if I wanted it.
DUH!!
:D
Page generated in 0.028933048248291 seconds with 17 queries,
spending 0.01053762 doing MySQL queries and 0.01839542 doing PHP things.
Please support our sponsor.
